help pick out an AM2 mobo
Specs of all the other stuff he has already would help...
But for my brother's system I'm building him, this is the core system.. I'm just waiting for the graphics card and power supply to come on Thursday so I can boot it up.
- AMD X2 3800+
- MSI K9N Platinum SLI
- 2GB OCZ DDR2-800 EL Platinum (4-5-4-15 @ 2.1 volts)
- XFX 7900GT OC 256MB DDR3
- 74GB 16mb cache Raptor
The guys on XtremeSystems seem to rate the Abit KN9 SLI over the MSI but imo it's still too early & not enough feedback on any of them & AM2 in general.
Abit has always been pretty good for me (more on Intel than AMD, but still not bad either way).
M2N32-SLI Deluxe is an excellent board. I'm running it and it worked fine. Just gotta figure out how to get the memory to work at 1T.
If he wants to keep the m2n-sli, he can order off of Zipzoomfly. I ordered half my build from there. Great service, good prices, and quick shipping. Got 2nd day shipping for only 2.99! :D
+1 on the MSI K9N. Just got my brother's up and running with 2GB DDR2-800 with ZERO issues whatsoever. Its amazing.. the computer is sooooo fast compared to my 3400+. There are tons of overclocking features as well, though I am not overclocking it.
The Asus board costs way too much money IMHO...although I did see a SLI 570 chipset version for only $145 or so. MSI gave me too much grief with their K8N SLI Neo4 Platinum board which didn't work right with Winchesters :(.
this is everything he was going to get.... but the Mobo isnt on its way so we need to figure out a replacement
http://www.newegg.com/Product/Product.asp?Item=N82E16819103631
http://www.newegg.com/Product/Product.asp?Item=N82E16813131013
http://www.newegg.com/Product/Product.asp?Item=N82E16820227045
http://www.newegg.com/Product/Product.asp?Item=N82E16814130281
http://www.newegg.com/Product/Product.asp?Item=N82E16822136009
i was thinking the MSI was a good way to go... the wireless asus though, do you lose any performance ? ive never been a bit fan of wireless (mice, etc)
you won't HAVE to use the wireless.
Why the slower DDR2 533 when you could be using DDR2 800? You can actually pick it up for cheaper and have faster memory..
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590 - $164 AR
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590 - $177 AR
etc..
And they had the sales of the OCZ EL Platinum 2GB DDR2-800 for $150 bux just last week.
the new abit am2 boards look like real nice boards.as an asus fan im looking at going abit this time but will wait for the ultra to appear,if not then the sli.also want to see the dfi line up.
he voided his sale and is going to buy after he gets back from the CPL.
i did not suggest those links, one of his friends did, im simply finding a better solution for ~ same amount of money.
as for the dd2 pc2 6200, that sounds good to me, but is corsair necessary usually corsairs a bit pricey?
the msi k9 is a piece of poop! ghet the asus m2n-e or something if he doesnt need sli. the msi k9 boards northbridge get too hot! so i returned it :)
Alot of MSI boards seem to to have that overly hot northbridge issue. It's nothing that another fan can't fix.
In other news, the K9N was my top choice until I read some of these reviews on it http://www.newegg.com/Product/Product.asp?Item=N82E16813130048
^^^ then again, it's not like Newegg reviewers know a whole lot ;).
I'm sure they tested and tested the MSI boards for stability and temps.. someone had to engineer that heatsink on the MCP chipset of the K9N Platinum SLI. I've gamed on it for a few hours straight in F.E.A.R. at all max settings, and left the computer on for hours on end, no problems at all. Of course if you touch it with your fingers, it is going to be hot. I would not recommend touching it while the computer is running just because of the risk of damaging something. But.. remember, these are pretty darn fast computers, they generate heat, and yes, these products have had to pass some sort of benchmarking/testing for heat disipation before being put on the market. I just think there are tons of newbs out there that don't know how to properly cool a computer case, or damage the mobo/mem/proc/graphics before they even get the computer up and running.. then they blame the person who makes their component. (most of the time, I'd say this is the case, unless it is a known defect where the manufacturer does a revision) I also think some of the problems people have with AM2, is they don't specifiy their settings correctly for everything in the BIOS. They'll leave their memory set to auto, have incorrect voltages/timings, order memory not tested by the manufacturer for approval, and the list goes on.. My recommendation would be to assemble the computer properly with an anti-static wriststrap, research all your components before hand just not to get the 'cheapest deal', have well routed cables for proper cooling, have plenty of fans in your case for good airflow to disipate the heat so the heatsinks can do their job with fresh flowing air.
