I have a (i think) 4 year old xps 730. I have pasted the output of cpu-z for my current system specs.
I mainly play games, currently BF3. I live in Monroe, la.
I might have $300 for upgrades in the next 30 to 45 days.
I'm going to be doing a new gaming build in the feb/march time frame, so any upgrades should be usable in the new system (1155 w/2600 or 2500k, not sure on the cpu).
BF3 plays ok for about an hour on my current system, then the fps dump and i have to close game and restart. All temps seem ok. Thinking maybe the 4GB of ram or the hd is the bottleneck.
Thoughts?
GPU is Nvidia (not an oem straight from nvidia) gtx 560 ti
CPU-Z 1.49 report file
Processor(s)
Number of processors 1
Number of cores 4 per processor
Number of threads 4 per processor
Name Intel Core 2 Quad Q9450
Code Name Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
Package Socket 775 LGA
Family/Model/Stepping 6.7.7
Extended Family/Model 6.17
Core Stepping C1
Technology 45 nm
Core Speed 3480.3 MHz
Multiplier x Bus speed 8.0 x 435.0 MHz
Rated Bus speed 1740.2 MHz
Stock frequency 2666 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache (per processor) 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache (per processor) 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache (per processor) 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA nForce 790i Ultra SLI SPP rev. B1
Southbridge NVIDIA nForce 790i Ultra SLI MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Memory Frequency 696.1 MHz (5:8)
CAS# Latency (tCL) 8.0 clocks
RAS# to CAS# (tRCD) 11 clocks
RAS# Precharge (tRP) 11 clocks
Cycle Time (tRAS) 27 clocks
Bank Cycle Time (tRC) 37 clocks
Command Rate (CR) 1T
System
System Manufacturer Dell Inc.
System Name XPS 730
System S/N JXDS5H1
Mainboard Vendor Dell Inc.
Mainboard Model 0F642F
BIOS Vendor Dell Inc.
BIOS Version 1.0.4
BIOS Date 06/24/2008
Memory SPD
Module 1 DDR3, PC3-8500G (533 MHz), 1024 MBytes, Samsung
Module 2 DDR3, PC3-8500G (533 MHz), 1024 MBytes, Samsung
Module 3 DDR3, PC3-8500G (533 MHz), 1024 MBytes, Samsung
Module 4 DDR3, PC3-8500G (533 MHz), 1024 MBytes, Samsung
Software
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600)
DirectX Version 10.0
Thoughts?
Processor(s)
Code Name Yorkfield
Core Stepping C1
Technology 45 nm
Chipset & Memory
Memory Type DDR3
System
System Name XPS 730
System S/N JXDS5H1
BIOS Version 1.0.4
Memory SPD
Software
