Help On Web Browsing, Media, Skype Build
Lights Out
Okay I'm looking to build an extremely basic computer for a family member, she won't be doing anything crazy. My knowledge comes from computer components for gaming pcs but not so much for a basic computer. I want it to be fast but I don't want her to have power under the hood that she will NEVER use.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Web browsing, video chatting, maybe some youtube watching, extremely basic photo editing, if any. Basically this is going to be a pretty basic computer
I'd like to keep it under 600. Of course the cheaper the better, I don't want her spending unnecessary money.
Wallington, NJ. If you're wondering, yes I have a microcenter by me.
CPU, Ram, Case (preferably a small one), power supply, cd drive, motherboard, hard drive, 21"-22" monitor, mouse, keyboard, video card (unless I get the i3 which I believe has the onboard GPU, should be sufficient for this use correct?)
none
6) Will you be overclocking?
no
n/a
within a week or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
onboard GPU if you suggest this over a dedicated card
No, I will need to purchase windows. I will go with windows 7.
For the most part I think I can figure out the build but I'm definitely look for input on the CPU, Motherboard, Ram and the GPU (unless you recommend an i3 and using it's onboard GPU)
Go with Danny Bui's build. It expires tonight.
The best that I could do (from Micro Center, without going cheap on every part) is the following:
$50 - Intel Pentium G645
$80 - Gigabyte GA-H61N-USB3 mini-ITX motherboard
$35 - Crucial Ballistix Sport 2x4GB DDR3 1333
$68 - Toshiba 1TB OEM HDD
$16 - LG GH24NS72 SATA DVD burner
$70 - Thermaltake Element Q mini-ITX desktop case (with 200W SFX PSU)
$20 - Logitech MK120 USB wired keyboard and mouse set
$120 - Acer G226HQL 21.5" 1920x1080 monitor
+$16 - Sales Tax from NJ Micro Center)
$475 - Total from Micro Center
Granted, these aren't all the best parts I could find. Some of the better deals available, like the Seagate 2TB HDD for $100, would burst your budget. And it's currently cheaper to buy a copy of Windows 7 online than in store.
