Help on picking RAM
Kaerugreen
Hardcore Gaming, Using Maya a lot, streaming my game play.
around 80$
USA - Orlando, Florida
Need new RAM, would like to keep the same amount I have now.
Motherboard = EVGA 131-GT-E767-TR LGA 1366 Intel X58 SLI3 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Chip = Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core Processor
Display = NVIDIA GeForce GTX 660
Power Supply = 750W OCZ Fatality Modular Gaming 80Plus Bronze Power Supply
Ram = OCZ Obsidian Series 12GB (6x2GB) 240-Pin DDR3 SDRAM 1600(PC3 12800)
Case = Cooler Master CM690 (good size with lots of fan space)
6) Will you be overclocking?
No
7) 7) What is the max resolution of your monitor? What size is it?
24" Dell - Max Resolution= 1920x1200
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 64bit
Closing Statement
I was told in another thread that my RAM was not supported by Intel i7. I am still having the issue where my computer resets and I am on my last straw with this. I've replaced every single item in my case, including the case, except the chip and RAM. I am just looking for a good choice of RAM for my setup that will not give me any problems.
Thanks!
The problem is that at this point the damage is done. As such, you will more than likely have to RMA that CPU even with the new RAM.
Go for this RAM anyway:
$80 - 2 x Patriot PSD38G13332 8GB DDR3 1333 RAM
