Overthelimit
- Sep 29, 2006
Hi, I just bought a system with the following specs:
A64 3500+
Infinity RS482 Mobo
2GB DDR400 Memory - Dual Channel
200GB SATA150 Hard drive 7200rpm, 8MB cache
It is currently running on an integrated ATI Xpress1150 GPU..
What graphics card would you recommend for the system at various price levels so that it fits well with the rest of the PC? I want to be able to play Oblivion, FEAR, etc fairly well but don't want to spend too much seeing how fast graphic card prices drop. Thanks for any recommendations.
Also, should i wait with the integrated graphics now so i can get like a x1900xtx later for cheap at DX10 launch or something, because I think all the current cards will be much cheaper when the DX10 cards come out.
A64 3500+
Infinity RS482 Mobo
