Help on new Build
Heck101
My Build:
SAMSUNG 24x DVD Burner - Bulk SATA Model SH-S243N/BEBS LightScribe Support - OEM
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
XFX HD-487A-ZWFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ...
1TB HD and Will Run Windows 7
Everything is hooked up but I can get a video single, Tried a different Video Card but no luck any ideas on what else to try?
Hit up the stickied "Basic Troubleshooting Guide" and follow the steps on what to do when the system does not POST.
Post back with your results after you've followed the guide.
take out all your ram and only use 1 stick, if that doesn't work, use another stick of ram or even better use a known good stick
i fins that if i have some bad ram, it just never gets the video signal...
