HELP! Old IT guy builds new gaming PC.
Uncle Meat
So I used to build my own systems way back in the day. Then I started making enough money where I could afford to let someone else build my machines. SO for the past 10 years or so I've been buying either high end Dell XPS systems or more recently Alienware offerings. Well I've got the itch again to buy and assemble a new gaming rig for myself. Nothing too radical mind you... I plan on sticking to an air-cooled system versus water-cooled with the intent of playing around with some minor overclocking on occasion. Now I've got a pretty good idea on what major components I plan on using for this build, but there are a few areas when I need to some help from those in the "know". Let me break down what I plan on getting first...
Case: UNK
PS: Seasonic? UNK
MB: ASUS P8Z68 V - Pro
CPU: i7 2600K
CPU Cooler/Fan: UNK
RAM: Corsair Vengence 8GB DDR3 SDRAM 1866 (PC3 15000)
GPU: Radeon 69XX series (will run just 1 card to start, but need the ability to add a second)
SSD: UNK (Would like to run dual SSD's in Raid 0)
HD: 2 each Western Digital Caviar Black 1TB 7200 RPM SATA 6.0Gb/s
So I was hoping my fellow forum members could make a few suggestions on some parts I've yet to make up my mind on.
1. PC Case - System will be strictly air-cooled. Not looking for any BLING here... looking for funtion over form. Don't need or want any case lighting.
2. CPU Fan - What's the hot ticket as far as CPU fans for the i7-2600K?
3. Power Supply - I'm told/read that Seasonic makes damn fine power supplies. I was leaning towards the X-850?
4. SSD - I'm just not versed on SSD's so I don't even know where to begin. I know I want a pair in raid 0 for the OS, I'm thinking a pair of 64GB units will work fine, but which brand?
So I am soliciting suggestions for my missing pieces and parts. Any and all info is welcome.
TIA
U.M.
You should probably have posted in the General Hardware subform, but not a big deal.
1. Although there may be better options with reference to hard-drive clearance and tool-less design, I always end up going with the Antec 300 on machines I build for customers due to its clean, simple looks.
2. The Cooler Master Hyper 212+ and Xigmatek Gaia are both great and cost $30...diminishing returns on just about anything in comparison (although there are some other good units in this price range).
3. The X-850 is really overkill, but nothing wrong with it. The Corsair 650tx would be great for your setup. I would guess your load power consumption on that build will be around 450-475w at the wall in games. If you do want to add a second card, the Corsair 850tx would also be great, and a lot more affordable than the X-850.
4. Hard to go wrong with Intel, and their new 320 series, for reliability. Very little if any real world gain from raid SSDs for your use. The Crucial C300 drives are popular for speed. Personally had bad luck with Corsair's SSDs in customer machines, and would not use them again.
Also:
No point in buying the 2600k over the 2500k for games http://www.anandtech.com/bench/Product/288?vs=287&i=47.48.49.50.60.61.62.129
Personally had great luck with Asus' 1155 boards
No real world performance gains to be had from running faster than 1333mhz memory, you could save money there as well.
Id recommend Coolermaster 690 II Advance, very good case for the price, also if you dont want the front fan light, then you can change with regular fan.
Thermalright Venomous-X or Prolimatech Megahalem if you planning on overclocking the chip.
Coolermaster 212+ also a viable solution for reasonable price.
I'd get TX-750 or TX-850 (corsair), unless you want something modular (HX750/850)
64GB ssd, Crucial 64GB C300?? may be
1. Currently CM 690 II Adv is the bang for the buck. Just replace/cover the led's if you dont want the glow.
2. Im very happy with Cogage True Spirit, you can get one w/ the 1156 bracket. Its cheap (<$40) and does pretty damn well.
3. Seasonic is a respectable brand in making power supplies.
4. Whatever has Intel/Sandforce controller.
I've moved this over to General Hardware where it belongs.
1) I recommend any of these cases:
$70 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$110 - Lian Li PC-60FN ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$127 - Fractal Design Define R3 Black ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$150 - Corsair Graphite Series 600T ATX Case
$155 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$160 - Silverstone RV02B-W ATX case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
$220 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$230 - Silverstone FT02B ATX Case
$220 - Lian Li PC-A71F Black ATX Case
$230 - Lian Li PC-V1020A Silver ATX Case
$250 - Lian Li PC-V1200B Plus II Black ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
$330 - Silverstone Temjin SST-TJ07B Full Tower ATX Case
2) I recommend these HSF:
$30 - Xigmatek Gaia SD1283 120mm HSF
$29 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
3) You should be fine with the Corsair 850HX 850W.
4) Go for Intel's 510 or Crucial's C300/m4 series SSDs.
HDD wise, ditch those WD 1TB drives as they perform roughly the same as these cheaper Samsung drives:
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
RAM wise, there's very very little real world difference between 1866 RAM and 1333 RAM. As such, you'll be fine with this RAM:
$70 - G.Skill Ripjaws F3-10666CL9D-8GBRL 2 x 4GB DDR3 1333 RAM
As for the rest of your parts, please answer the following questions:
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Okay big thanks for moving my thread where it will get the proper attention! Thanks to those who have responded with replies and suggestions.
As for Danny Bui's direct questions...
1) This is primarily a gaming system with some video/photo editing thrown in. I'd say 80% gaming, 20% video/photo editing.
8) I'm planning on buying my components this week.
9) RAID = Yes, Firewire = No, Crossfire/SLI support = Yes, USB 3.0 = Yes, SATA III = Yes, Onboard video = No.
So I've made some changes to my build. Some based on recommendations and reviews, some just for S&G's. Keep in mind that while price is not the main factor for me when buying components, quality and sometimes a little over-kill/over-engineering is. I'm not doing a "budget" build here, nor am I trying to build a Cray. Just a gaming box I can play around with some over-clocking if I so desire.
So here's the latest list of components for your review/comments:
MB: ASUS P8Z68-V PRO
CPU: Intel i7-2600K
CPU COOLER: Cooler Master Hyper 212 Plus HSF
GPU: Still undecided!
MEM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) CMZ8GX3M2A1600C8
CASE: COOLER MASTER HAF X RC-942-KKN1
PS: OCZ ZX Series 850W Fully-Modular 80PLUS Gold
SSD (For OS): Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5" 128GB SATA III MLC
HD (For Storage): Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5
Blu-Ray/DVD/CD: SONY Black Blu-ray Burner SATA BWU-500S
New questions...
1. Is 16GB of RAM going to make any difference as far as gaming? I know the extra RAM may come in handy for video/photo processing.
2. Should I run 2 smaller SSD's in RAID 0 for the OS or better off just getting one larger SSD to host the OS?
3. Video card!?!?!? I'm torn as to what video card to choose. My current system has a pair of 8800 GT Ultras running in SLI. However I'm only running an older 24" Dell Ultra Sharp (1920X1200 max res) so an SLI or Crossfire solution is probably way overkill, however I would like to move up to multiple monitors in the future. So should I be looking at a something in the Radeon 69XX series or Nvidia's GTX 5xx series?
U.M.
CPU: Intel i7-2600K
New questions...
U.M.
1. 16GB is not neccessarily going to help for gaming. I don't use a swap file for my SSD anyway, so I need to have a little extra ram. I'd say if you can get a cheaper 4x4GB kit, like the one on Shell Shocker today for $99, get that. It'll help for your other endeavors, but the big jump is from 4 to 8GB. After that, you're not going to get much or any benefit in gaming terms. But if memory suddenly jumps in price, you'll wish you'd bought more.
2. I'm not a fan of RAID arrays for the OS drive as far as SSDs are concerned. One of the new Crucial M4s/Intel 5xx series, Vertex 3s, or Patriot Wildfire/Corsair Force GT are fast enough on their own. I'm not sure you'd get the kind of sofware raid performance boost that you'd get from a pair of slower drives. You'd get some impressive numbers when benching, but in terms of real world performance you're better off getting a single, fast, reliable drive. 256GB drives are faster, but 128ish drives don't lose as much. Also, you can't TRIM a raided SSD, and trim is important for long term performance.
3. I love my UltraSharps. I say get one GPU. I wouldn't bother going through the trouble and expense of doubling up unless you went to a 30" 2560x1600 or Eyefinity. That's just my opinion, but I like one quiet, cool and efficient card to run games at the 1080x1200 resolution. Noise is important to me, so SLI/Crossfire is effectively out with air cooling for me. A 560 Ti, 570 or 6950 would probably do you for a good long while. Again, this is a philosophical issue. But loud systems are awful. Loud systems sound like old systems to me.
Just my opinion. It's kinda hard to go wrong, but it's the little things that make a difference. Also, I'm using a Seasonic X-650, and it almost never has to spin up the fan.
Recap:
Soft RAIDed SSDs are more impressive, but more trouble and you lose one of the important tools to keep the drives working fast.
More ram is always better, you don't neccessarily need the fastest RAM with SB, 4x4GB kits are good, but 8GB is mostly always acceptable for anything.
I believe one quiet cool running card is better than two, but if you're not running Eyefinity or nVidia Surround 3+ monitors or one 30" Ultra Sharp, stick to one card.
Not a good choice for the money IMO. In the case list I posted earlier, many of those cases are better buys than than the HAF X in terms of quality and cooling.
Again, I recommend ditching this drive as it performs roughly the same as this Samsung drive:
For gaming, no.
Larger SSD.
You should be fine with the GTX 560 Ti, HD 6950 2GB, GTX 570, or HD 6970 2GB.
I concur with the above.
On the case, I'm fond of the Lian Li PC A05nb. Might not be the best choice for two GPUs though.
What programs are you using for video and photo editing? If gaming is going to take up 80% of your time, then you could get by with the Core i5-2500K.
I just purchased a Cooler Master HAF X myself, and after instant rebates and a $10 MIR, it was only $160 @ Newegg. Totally worth it, and I never spent more than $80 on a case before.
I agree with tiraides about the i5-2500K. Gaming will not gain anything at all with HT, and its been shown that one gets much better OCing results with HT off anyways.
As a random aside, I know a decent amount about parts and I understand that 8GB >> 4GB however is it possible to run (2x2GB) + (1x4GB)? What are the advantages/disadvantages to doing this?
My room mate has 4 in his.
But to the OP-
Stick with 1 larger SSD for your boot drive. RAID will disallow you from taking advantage of TRIM support. I have a C300 128gb drive, and it is amazing. I am sure there are faster ones out now, but I would definitely recommend it if it is in your budget.
Ram-
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148347
Shell shocker today, decent deal. I would probably shell out for 1600 though. 8GB is sufficient. To the post above mine, don't run 2x4gb+1x4GB if it is a dual channel board.
2500k vs 2600k- I shelled out for the 2600k and couldn't be happier, but I take advantage of the HT, while gaming probably will not.
Case- I own 2 of these, they are really nice IMO
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112318&Tpk=k57
140mm intakes and side grills allow you to have a higher cfm/noise ratio than 120mm fans. Also, the cable management on this case is great. If you are planning to pay more for a case, you can probably find something marginally better, but this is probably the best value for what you describe. I have 4 gpus in each box and they run 24/7 rock solid.
edit: also- I would run to your local best buy and see if they have any of the corsair H50's that are on sale for $40. You won't beat the price/perf. ratio. I know you said air cooling, but the H50 is ridiculously easy to install
edit2: Check out the Anandtech Bench for gpu comparisons if you are torn-
http://www.anandtech.com/bench/Product/293?vs=306
I bought an open box 6950 on newegg for $180
Well components were delivered yesterday and I had a funtioning system up and running within a couple hours. Here's the final list of components that went into the new build:
CPU: Intel i7-2600K
GPU: Sapphire HD6970 2GB
MEM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) CMZ8GX3M2A1600C8 8-8-8-24
PS: Seasonic 850W Fully-Modular 80PLUS Gold
SSD (For OS): Crucial M4 CT256M4SSD2 2.5" 256GB SATA III
HD (For Storage): Western Digital Caviar Black 1.5TB 7200 RPM SATA 6.0Gb/s 3.5
Blu-Ray/DVD/CD: LITEON Black Blu-ray Burner SATA BWU-500S
System went together quickly and without issue. Booted up with no errors and Win 7 was loaded to the SSD. Everything worked correctly right out of the box. Only issue I need to resolve is the front panel headphone and Mic jack connection to the MB. The cable that comes from the HAF 932's front panel to support the headphone/mic jacks has two connectors on it. One marked AC97 and the other says HDAUDIO. I plugged the AC97 into the MB audio header and neither of the jacks are currently functioning. I got a feeling I should have used the HDAUDIO plug instead. Will try that tonight when I get home. Additionally I'm a little perplexed as to why device manager reports not only the Realtek 8-ch audio device, but some AMD device too? Anyone know what that is referring to?
As for the 256BG Crucial M4 SSD all I can say is HOLY FREAKIN' CRAP BATMAN! After installing Win 7 and making the necessary/recommended adjustments/tweaks to support the SSD I ran HDTUNE and the average read speed was 478MB and the write was something over 350MB! I may be off a little on these numbers... I'll grab the for real numbers from HDTUNE when I get home and post them up, these are from memory. I know that both read & write speeds well exceeded the stated rates from Crucial!
Windows 7 experience score was 7.6.
I'll load up 3D mark tonight and see what numbers it spits out.
Now I'm looking at getting some additional monitors for eyefinity use and possible a 2nd Sapphire 6970...
Thanks for the help and suggestions everyone provided!
U.M.
That's the HDMI audio part of the Radeon chip. And with modern mainboards, they will usually have the HD format for front panel connections. It will auto detect when you plug something into a jack, and you have to set up if you want to mute this or that when something is detected.
SSDs rock, did you do the power state fix in the registry too? I'm getting an M4 with my new build, and I'm curious if I will need to perform this tweak.
Wasn't sure what you were referring to so I did a quick search and I guess some owners are seeing Windows freeze and it is supposedly due to LPM? Appears it's mostly laptop users with this issue but there are desktop users seeing it too. I haven't had windows freeze on me yet, but then again I've only got a couple hours of use on the box thus far.
U.M.
You may also want to think about adding a nice PCIe sound card to your setup. I recently upgraded from onboard sound to a Creative X-fi and it made a world of difference on my 5.1 setup and my headphones.
You are correct on this part. AC97 is the old headphone/microphone standard, any board which comes with onboard HD Audio will use the HDAUDIO plug. Of course, if you're feeling lazy most boards give the option in BIOS to change the HDAUDIO header to work with an AC97 jack. ;)
And as vick1000 remarked, the AMD sound device is your HDMI audio. If you ever feel like hooking up your computer to a nice HDTV and playing sound over the HDMI cable to that or a receiver, you can just change the default audio device under the Windows Control Panel.
