RanceJustice
- Jun 9, 2003
Ran full Memtest overnight - 19 passes with no errors. Any idea what's causing the problem or something new to try?
i love that. note carefully, it tells you the minimum is too lowXaeos said:Uh oh. About 1 hour, 24 minutes in, Windows is telling me that my page file is to small. Maybe all that paging is a bad thing? I've not increased the size from default, but it doesn't seem logical to me that a CPU/RAM test should be paging to HDD, rather than the RAM itself
Is this how SP2004 is supposed to work, or is it indicative of a larger problem?
Edit: Test has run for over three hours with no further warnings. I wonder if it had to do with all the stopping and starting to find a low enough frequency. Still makes me edgy
mmk. guess that plan is out.. hahaXaeos said:Switching to the other two slots give me all kinds of problems - no error message, but the system just hangs during boot. Switching back to the regular slot, boot is fine again.
Edit: Any idea why my CPU speed is shown as 2592 instead of 2605 like we calculated?
there's an easy way to find out if it's the ram or HTT.. drop the memory ratio down one notch. if it's still not stable, drop the cpu multi too. that'll prove that it's the htt.Xaeos said:Popped ClockGen back open and started downclocking
At 2458 CPU, 273 HTT, and 223 RAM things seem to be stable again. At least, SP2004 Blend doesn't stop. I still get those "paging" blocks every so often, but I don't think that indicates instability.
Judging by the fact that the Small FFT test was just fine at 2592mhz, I'm assuming that either the HTT or the Ram require these lower timings? Bah. This is so weird, considering that the Ram passed Memtest at 237. I'm assuming its the RAM, and not the HTT that's causing the problem. Any idea of what to do next?
Or should I look into gettting a decent CPU clock of at least 2.5 with Ram at 223 somehow? Bah. I hate to move backwards
yesXaeos said:Edit: I just read your post another way. Did you mean that I should go back to the CPU overclocking step of the OC guide at the different voltages? Ie. Change all the specs back?
