RanceJustice
- Jun 9, 2003
Hello all. I'm preparing to go over my first AMD overclock ever - my Dual Core Opteron 165 on a Biostar Tforce6100 939 mATX mobo. So far my system idles at around 28c stock, with a Zalman 7000B-CU as the cooler. I'm planning to follow Eclipse's OC guide exactly, unless anyone had some better methodolgy to add since it was written. I'd appreciate a little help in the process. Here are some difficulties I've encountered so far, clipped from another thread. At this point it seems some terms don't match up with what my Bios likes to name things.
"Am I to understand that what he (Eclipse) calls "HT Link Multi' = HT Frequency? Is "CPU Multi" = "Hammer Fid control"? Also, when he talks about the "Ram divider 100mhz 1:2" I don't see any ratios in the Bios. Does this mean to set "Memclock frequency" to 100mhz? Thanks!"
Any solutions here? Also, should I do anything different on the grounds that my proc is 1) dual core and 2) an Opteron? Someone told me that Opterons should be treated like FX level consumer procs.
