stoney_titan
- Feb 19, 2007
Well i finally built a new and first rig and i have a mess of a problem on my hands. It's simply terribly unstable. I will get into vista 32-bit (sometimes after multiple boots) and start to configure then complete blackout, fallowed by a single beep and a reboot. Vista also runs smooth as butter until it happens. Here are the specs:
E4300
DS3 1.3
Xclio 500w Goodpower
Gskill 2gb pc6400
centurion 5
160gb seagate hd
8800gts 320mb
Things i've tried (All noob troubleshooting of course):
1. Removing motherboard battery for 5min and replacing.
2. Re-seating video card and other cables.
3. Using only one stick of the 2, then switching. Same results.
4. Different drivers, and so on.
5. Upping voltage on RAM from 1.8 to 2.0.
The problem doesn't stem from putting load on the system either. It's completely spuratic.
I would do memtest, occt and other benches but it'll crash just opening them occasionally so their not going to do much good now would they.
Temperature is also ok. My e4300 doesn't even load past 50C during the 10-15 mins the os stays going during occt. HELP!!!! Please!!! Fast!!!!
P.S. As i was sitting here typing on laptop my rig crashed just sitting on the desktop.... No programs running at all!!! Fuck!
E4300
DS3 1.3
Gskill 2gb pc6400
centurion 5
160gb seagate hd
8800gts 320mb
