Help - new computer build is not working
nuclearactiveguy
Ok so i have a new pc build and have a problem
my computer will turn on, for about 2 seconds then turn off for 1 second.
pretty repeats this forever until i unplug it.
anybody can help me?
i was following newegg's guide to build a pc. trying to hear the small beep. i cant hear anything. honestly i have not plugged a monitor yet. but none of the lights will turn on or the case fans . but the power button will turn on
Yes, if you did not install the stand-offs you could have even fried the motherboard and everything plugged into it also.. good luck..
well actually everything is working. i installed the MB with the standoffs but also, everything is working. but its turning on and off... the same way.
nothing is fried. but its all just not going.
one thing i noticed is that the small motherboard fans. (I bought a asus z77 with the shields)
the small small fans are turning on ans so is the cooler. the lights are all on too. but nothing is STAYING on
try reseating the CPU... use fingernail polish remover and a qtip to remove the thermal cream.. reapply a very thin, even layer before putting the heatsink back on.
Specs of the PC would help. Also, follow post #3 in the stickied "Basic Troubleshooting Guide" on what to do when the PC does not POST.
ok
specs are
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
Item #: N82E16
CPU Replacement Only Return Policy
$309.99
2
AMD Gift - AMD Gaming Evolved Three For Free Coupon
Item #: N82E16
Standard Return Policy
$199.98
($99.99 ea)
1
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131821
$239.99
1
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Item #: N82E16835103065
$29.99
1
HITACHI Deskstar 7K3000 HDS723020BLA642 (0f12115) 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822145473
$139.99
1
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C10D-16GAO
Item #: N82E16820231558
Memory Standard Return Policy
$114.99
1
G.SKILL 4GB Micro SDHC Flash Card w/ SD Adapter Model FF-TSDG4GA-C4
Item #: N82E16820231509
$4.99
1
CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Full Modular ...
Item #: N82E16817139015
$199.99
1
LOGISYS Computer LDKMTRD1 Single Red Meteor Light Kit
Item #: N82E16800888052
$9.99
2
DIAMOND 7970PE53GDD Double Black Diamond Edition Overclocked Radeon HD 7970 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready ...
Item #: N82E16814103201
VGA Standard Return Policy
$939.98
($469.99 ea)
1
ASUS Black Blu-ray Burner SATA BW-12B1ST/BLK/G/AS
Item #: N82E16827135252
$89.99
Shipped from NJ, USA - Tracking #:
1
NZXT Phantom PHAN-002OR Newegg Exclusive Black Finish w/Orange Trim Steel / Plastic Enthusiast ATX Full Tower Computer Case
Item #: N82E16811146073
Now follow that stickied "Basic Troubleshooting Guide"
I wonder if the heatsink isn't seated properly. The system keeps shutting off because CPU temps are skyrocketing.
will do again. sorry, im just worried but i need to maintain calm.
i think it might be my processor thats dead
Unless you incorrectly installed it, the chance of the CPU being dead is very low. Still can happen but very very low. The motherboard is the more likelier culprit than the CPU. Although since this is your first PC build, it may be just a PEBKAC issue and you didn't hook up a cable correctly or something.
In fact, don't you have that friend with the same motherboard? If so, see if you can test your RAM, PSU, GPU, SSD, DVD burner, and hard drive in his PC to rule out those parts.
will do. and yes i do. but hes in the army and in afghanistan so not rly a option
Ok. can you tell me how to test each of those? if you have the time of course
Well the first test is easy: Keep swapping in parts until the PC starts/stops exhibiting issues. However this requires you to have a working/booting CPU and mobo.
Actually the second test also requires a working/booting CPU and mobo and involves you using a variety of software to test the hardware.
Unfortunately, you can't do that with your current PC since it's not working/booting correctly. So follow that guide and figure out what's causing the issue. Make sure that you've connected all the necessary cables and power plugs. Also make sure that there aren't any screws and such loose on or under the motherboard.
i just noticed that my power supply keeps turning on and off, it makes a small noise then turn off. like every 2 seconds
Did you turn on the monitor? Did you connect the monitor to the video card?
everything just worked all of the sudden. im on the BIOS right now. the only thing is that my screen says
"CPU fan error"
but the CPU fan is spinning and all and keep the CPU under 30c
Did you plug in the CPU fan into the designated CPU fan header?
