Help! Need a good and stable 939 board
SaViOr-
Hey guys im going to be upgrading this summer to pci-express, i know most of the components that i want to get , r520 gfx card , 3800+ amd 64 (venice core or newcastle) , 1-2 gb ocz ram , ocz powerstream 520 or pcp&c 510 , audigy 4 , raptors , etc ....
Now i dont know what s939 mobo i want to get, I will not be overclocking anything in my system when i get it so i want stability over overclockability, Also i want to know how hard is it to set up 1-2 raptors if i've never done it before? Do i just put in the floppy when i install windows or how does that go? help is appreciated on aything and any other suggestions are welcome :) Oh and price wont matter since ill be getting a job after soccer season ends.
Thanks,
SaViOr
You'll definitely want to get the MSI K8N Neo4 Platinum SLI board. There is a lot of dispute between this and the DFI board. But since you aren't going to be overclocking, the MSI is the way to go. DFI is better than the MSI when you're overclocking because it gives you a higher voltage on the RAM, but you aren't going to need that. If you want the most stable board on stock speeds go with this board.
Since money isn't a factor you'll probably want to go with the SLI version and throw on two video cards. The only problem I have with this motherboard is that you have to have a power supply with -5V on pin20 if you want to onboard sound to work. The onboard sound on this motherboard is really good, so I would suggest buying the right PSU and using it instead of buying the separate audigy4. But if you're going to go with the audigy 4 no matter what, you have no problems at all with this board and can buy any kind of atx 2.0 power supply.
It depends on whether or not you want to get the OCZ VX Ram. That needs a lot of voltage and only the DFI puts out that much. If you just want regular TCCD or something along those lines, the MSI is a good choice also (I have an MSI myself).
Thx for the suggestion, but i wont be getting 2 cards for sli now, since the one r520 will have 32 pipes and has 2x the performance of any x850 xtpe , plus itll beat 2 sli'd 6800u's :) , but i think i will look into this mobo, ty
Link to your information?
MSI is good, so long as you're not overclocking, but I don't know why you'd want integrated sound over an audigy 4?
Here you go bud , info to r520 http://www.techpowerup.com/reviews/Cebit2005/Day4/5 , oh and i will be getting the audigy 4 just because i've heard the sound is alot better than the audigy 2.
I've looked at that msi board and over 50% of the posts on here say that the board is a b*tch to setup and that they have had alot of problems with it. So i dunno if i want to get it lol.
Any other suggestions? The board doesnt have to be SLI but if it is thats ok too, as long as i'll have no problems setting it up and getting it to run.
SaViOr
SaViOr
No it isn't. It's a LOT more expensive. $299 as compared to an Audigy 2 ZS for $80. It only increases Signal to Noise Ratio (108db) and adds one other feature I can't remember that does not justify its price. Do yourself a favor and stick with the Audigy 2 ZS.
regular zs or plat zs?
Oh and i want to get the ASUS "A8N-SLI Deluxe" newegg has 70 reviews on it that are all positive and almost all 5 star with the exception of 2 or 3 4 stars, would this board be a good pick to run with the ati r520 ?
All the Audigy 2 ZS cards are the same. It's "Extras" that drive the price up. Like the software bundles and that "control center thing" that takes up one of your 5.25" bays. IMHO not worth it.
Asus A8N-SLI is "hit or miss" from what I have seen. Don't base your choice on what users have been saying on Newegg. Go look into forums and see the "issues" that people have been having and then decide for yourself if this is the right board for you.
There is no information that says the r520 (which isn't out yet) will run well with this board. Too early to answer that. I think if you wanted to run SLI with the r520 that it WOULD NOT work on this board just based on the fact that current ATI cards do not run in SLI. SLI works on these boards with a connector that connects 2 nVidia cards. This "port" is not on any ATI card. This may change with newer ATI cards--but again I cannot state that as fact. I don't work for ATI. ;)
I don't know where you got that information, but I'm a beginner at building computers, and this board was a breeze to setup. This is my first build, and I had no problems what so ever other than trying to get my onboard sound to work when I had the wrong power supply. Since you're not going to be using SLI, I would recommend the MSI K8N Neo4 Ultra. It is basically the same as the other board minus the SLI feature, and minus the SB Live! onboard sound, which wouldn't matter since you're getting an Audigy.
I've been browsing this board ever since the nForce4 boards came out, and I saw people have a LOT more problems and have had to RMA the Asus boards compared to the MSI. I've seen quite a few people post about their Asus nf4 boards just crapping out and dieing and then the people went out and bought the MSI to replace it and had no problems. But since "50% of the posts here say that the board is a bitch to setup" go ahead with Asus. I don't know how I missed those 50% of posts about the MSI, since I researched which nForce4 board to get for months
. Good luck with your Asus.
DFI Lan Party Ultra-D. Easy to setup, and fastest board at stock speeds if you use OCZ VX RAM since only DFI's can even use this RAM.
My Neo 4 Platinum hasn't been in my system very long, but it's been rock solid. I like DFI's board (LanParty NF4 Ultra-D) as well, but both have different features for different folks. I wanted the 4 PCI slots that the Neo 4 had (The DFI has only two, I'd be full up already), the extra 4 SATA ports, and I needed a serial port to program my Cisco router through the console (the DFI doesn't have an onboard serial port, just a header for one).
On the DFI side, it has two PCIe x16 slots (split to x8 if you use both) for a dual display rig if that's your fancy. If you're not going to go with a sound card, the Von Krajan audio setup is reputed to be a little higher quality than the onboard audio setups of other NForce4 Ultra boards. The maglev fan design for the NF4 chip is also cool, and the board also has the ability to supply additional power to it through a 5.25" Molex connector in case it's needed.
Both DFI and MSI have pretty good overclocking reps, though the DFI has the highest Vdimm settings around in case you wanted to use OCZ VX memory which requires a lot of juice. If you're not overclocking at all (just noted that), I'd say that for most people the MSI has a couple of extra features that are worthwhile, unless you know you want dual vid cards, or unless you know you're going to use onboard sound. If it were me, I'd go with a real sound card, and the MSI, my last three boards have been MSI and they've all been good.
VX works with any board, but DFI can natively give it the high voltages it requires for best performance. Other boards eiether need volt mods or a OCZ DDR Booster.
Back to the OP.
The MSI will have an easier setup than the DFI.
The DFI has a tweaker's BIOS, which sacrifices ease of use/installation for maximum configurability/Overclock. I very much like my Ultra-D, but it isn't for everyone. All the bad rap it gets on forums are mostly from people who don't want to put the time into getting the board configured properly or reasearching on the best memory timings/CPU parameters. If spending hours figuring out what TREF or Errata 94 enhancement is, the DFI board is not for you. The only "Auto"s I have in my BIOS are the ones that enable SATA and integrated LAN.
I do agree with Burner27 that the Asus board is hit and miss, I've seen them blow up in person just by running nTune on them (told him to do it manually :p )
That leaves MSI (Or Gigabye, but no-one likes them). Read reviews on the board, all the ones I've seen have been positive.
The MSI is a great board. It's not that hard to setup and most of the issues are with CPU voltage over stock.
