Basically my pump emits a very loud annoying noise smells of burning and doesn't pump water
The quick fix is to replace the pump. Problem solved.
I've sent an email to vibox but I'm pretty pissed off as I run a tribe on ARK which usually requires me to be on every day and atm we might be getting attacked by a bigger tribe so I need to be on today, that's what I meant by a quick fix and I wouldn't trust myself to change the pumpI hate to say it, but this
makes me agree with this
If I could somehow remove the pump and place a household fan on the CPU could that work as a temporary fix?
Absolutely not. If you just need to be up and running in a hurry, get a Hyper 212 Evo air cooler. Are you using an all in one liquid cooler? What brand is Vibox? Are they a PC builder?If I could somehow remove the pump and place a household fan on the CPU could that work as a temporary fix?
WatercoolingNo. What CPU cooling hardware are you using?
If you're not comfortable opening the loop and fixing it yourself with a new pump, your quickest method is going to be buying one of these and using it instead:Watercooling
Don't turn it on again until you've replaced that cooler, my man. You're gonna toast your processor.Also I shook my PC quite hard and some white powder looking stuff went into the tubes when I felt tubes it was very hot
Bro I got so much porn and shit on there I don't wanna send it for vibox for them to see also they wanna charge me £25 for the courier to pickup the PC and drop off after repairedDon't turn it on again until you've replaced that cooler, my man. You're gonna toast your processor.
I mean, it'll probably just thermal shutdown, but that's not exactly good for it either.
If you're that worried, just remove your hard drive. They don't need it to fix the cooling loop.Bro I got so much porn and shit on there I don't wanna send it for vibox for them to see also they wanna charge me £25 for the courier to pickup the PC and drop off after repaired
