HELP! My (good) system is EXTREMELY laggy
shG
My system is currently EXTREMELY laggy to the point where I can not even watch videos. I'm not exactly sure what the problem is, and what I can do. Please help me!
I've ran several tests already, but I can run more if people are willing to help me.
Problems I have noticed:
-Windows sometimes gets stuck at WIndows loading screen.
-While moving files, I noticed "spikes". The transfer would go dead for about a minute, and then start back up again.
-Videos would skip, and during these 'skips' the whole computer is lagged (I can still move the cursor, but there is no reaction), not just the video.
-The longer the computer is on, the more lag I experience.
This is my current build:
CPU: Q6600 CORE2QUAD G0
VIDEO CARD: eVGA Geforce 8800GTS 320 MB PCI Express HDCP Video Card
MOTHERBOARD: GIGABYTE GA-P35-DS3R LGA 775 Intel P35 ATX Intel Motherboard
RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
HDD: 500gb SATAII SEAGATE
DRIVE: LITE-ON SATA DVD BURNER
CASE: COOLERMASTER w/ 3 LED fans
COOLING: Thermalright Ultra-120 Extreme CPU Cooler
COOLERMASTER - COOLDRIVE 5
Here is a picture of a few tests I've ran. (core tests on the left, HDD test on the right)
I do have a suspicion that it is my hard drive. However, it's only 1 year old, and has been encased with a hard drive cooler for the entire year that it has been running. The Harddrive cooler does not use any gel pads. It's just a normal heatsink and fan.
Please help me, thanks
You could start by disabling programs that load on startup and run in the task bar. They always use up resources. Check task manager and see what's running and using processor and memory resources.
I am using only the bare minimum amount of programs. There are barely any resources being used on the computer, yet it was insanely laggy. My system was working fine earlier today, but it became like this after intense downloading and file transferring.
Called a restart... "intense" downloading esp if you're BTing will put a halt to any system.
I have restarted, that's why I notice windows gets stuck on the windows loading screen.
Do you have a spare drive? Back up your stuff just in case, then do a reformat on the OS drive to see if it remedies it. From the SS it seems you aren't O/Cing, yes?
Defrag often?
I do it three time a week if I'm mass downloading (astraweb FTW)
Well, I already have suspicions that it is my hard drive. But I just wanted to make sure it wasn't something else. Could it be CPU? motherboard? or videocard?
And if it IS my harddrive failing, can I get a warranty drive from seagate (i am within warranty period)? It's still accessible, but it's slowly dying.
SeaTool Results:
SMART check : Pass
Short drive self test : fail
Long drive self test: fail
Basic Information: pass
short generic: pass
long generic: fail
I have a brand new 750GB Samsung Spinpoint F1 32mb I'll sell you, shipped to your door for $90 (If you're in the lower 48). I did use it once to test it but beyond that it has sit in the plastic shell. I've sold here before.
Yeah, those results point to a failing drive. Contact Seagate customer support (have the drive model and serial number ready, sometimes they require a tentative date of purchase as well) and let them know what's going on and report the Seatools results to them. I've had Seagate send me a brand new drive when my old drive died 2 months out of warranty. Awesome company to do business with and very worth contacting even if you're unsure about your current warranty status. While the drive is accessible, I recommend backing up all important data (obviously) and not writing anything of importance to the drive until it's RMA'd.
