Hello,
I just upgraded my system to this:
evga 780 sli mobo
Q9450 quad core intel
4 gigs corsaur ram running at 1066 MHz
2 x 8800 GT 512 Mb in SLI
My current HD is a few years old seagate 320 gb drive (sata) Its almost full, and running very slow. Since I wanted to upgrade my OS to the 64 bit version of Vista home premium, I figure Ill re-do my HD/s at the same time since I have to do a clean install, Im decent with building my PC's but not on the level of some of you, and was hoping you could help me decide.
I am primarily a hardcore gamer, actually most of my recent upgrades are for Age of Conan which i hope is worth it...
OK, questions:
1. Do you recommend going with another single drive solution, or multiple drives?
2. If multiple, does a 10k raptor drive as the system drive, with say a 500gb 7,200 drive for my games, music sound like a good choice for performance? Which drives are best these days?
3. If that set up is a good one, can you tell me in "im an idiot" steps on the best way to do it? I recall having issues with drives not being detected by the bios, having to install drivers with F6 or something like that, etc. I do NOT have a floppy drive on here so do i need to copy the mobo floppy to a thumb drive or a cd/dvd? Can I install both drives at same time, then partion it all, then add the OS?
4. What partion size do you recommend, or do I leave the 2 drives as C and D and leave it at that?
I would really appreciate some guidance.
evga 780 sli mobo
OK, questions:
