Help me with my problem
BAC4D00R SP1D0R
Well I got a new Samsung 2493HM and I love it but only one nagging problem is the stupid touch sensitive menu buttons. Well here is my dilemma. When I was making my tweaks and I accidentally changed the language to something i don't' even know what it is. So does anybody know specifically in the menu on the monitor to change the language back to English.
Help will be appreciated
How about a hard reset of some type? Is there a manual? possible a manual online? 24/7 tech support?
called the company and they said sometimes it's accidental with a different language other than English.
thanks for ur help jstutman
Well I have a Gateway 24" with touch sensitive menu buttons. What you can do is pull the power cord out of the wall outlet, surge protector or whatever you have it connected to. Plug it back in and if your monitor is the same as mine it should come on once you plug it in. Then, the language menu should show up again.
Looking through the manual, in Setup, Language is the first or second option.
It's a lot easier than trying to find "factory reset" in a different language.
Good luck,
10e
