So, I am a gamer on a fairly tight budget, and my system is home built and a couple years old, though it has been serviceable enough I suppose. Yesterday I tried installing GTA4 though, and I ran into my first serious bottleneck problem, as I was only getting 9fps with everything on low, and using 100% of my processor. FO3 has also been running kinda chunky, so, I think it's time for an upgrade. My computer is below.
I'm trying to get by with upgrading the least amount, but to make it serviceable for at least another 18 months (i.e. until I graduate and get a paying job). Now, I'm not a big graphics junkie or anything, and my resolution only needs to go up to 1280x1024, so I don't think the graphics are the problem. Problem is in order to upgrade my processor, I need a new motherboard, and if I get a new motherboard, I will need new RAM. And I think my hard drives are both IDE, not SATA, so hopefully that won't be an issue. Anyway, I'm trying to upgrade it for <$300, and was thinking a new Mobo, Processor, and RAM would do the trick, and I could recycle everything else.
Any advice, suggestions, insight, questions, or comments would be appreciated. Thanks!
Computer:
Operating System Microsoft Windows XP Home Edition
OS Service Pack Service Pack 3
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name DAVEYJWINPC
User Name Dave
Motherboard:
CPU Type DualCore AMD Athlon 64 X2, 2233 MHz (11 x 203) 4200+
Motherboard Name Asus A8N-SLI Premium (3 PCI, 1 PCI-E x1, 1 PCI-E x4, 2 PCI-E x16, 4 DDR DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipset nVIDIA nForce4 SLI, AMD Hammer
System Memory 3072 MB (PC3200 DDR SDRAM)
BIOS Type Award (10/21/05)
Display:
Video Adapter NVIDIA GeForce 8800 GTS (640 MB)
Monitor NEC MultiSync LCD1760V [17" LCD] (3X404175TA)
Multimedia:
Audio Adapter nVIDIA MCP04 - Audio Codec Interface
Storage:
Disk Drive Maxtor 6L200P0 (200 GB, 7200 RPM, Ultra-ATA/133)
Disk Drive Maxtor 6Y160P0 (160 GB, 7200 RPM, Ultra-ATA/133)
Disk Drive WD 5000AAJ External USB Device (465 GB, USB)
Disk Drive WD 6400AAC External USB Device (596 GB, USB)
Disk Drive USB DISK 2.0 USB Device (1937 MB, USB)
Optical Drive PLEXTOR DVDR PX-740A (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW)
