Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I get that both the E17 and E9K are each headphone amplifiers (and with tradeoffs), but what benefit is there to the docking of the former to latter? Charging only?
it is pretty good.... however i have had issues with my E9 most seriously last week the 1/4" headphone jack shaft split and a large piece broke off...OOOOPS..... I took the front face plate off (you have to break glue holding volume knob) and managed to successfully glue the broken piece back in place. (my E9 was a refurb and as such out of warranty ....i had had it 8mos~ when the headphone jack broke.)
the other issues with the E9 scratchy/noisy volume pot and volume knob was rubbing aluminum front panel when i got it.
took front face off and used some deoxit on the volume pot and put some washers between knob and face plate so far this has solved the noisy vol pot and scraping issues.
the E07K i just got for xmas..and it has been fine (so far)
however if you don't need a portable amp if i was doing this again I know I would be getting the Schiit Magni / Modi ($99each) usb dac / headphone amp..... instead of the FiiO stuff I have now.
to it's credit when it isn't breaking the E9 seems like a fine headphone amp and the E07K has been quite nice.... it is much cheaper than the E17 ($89~ for the E07K and $135~ some for the E17 so you might want to look at the E07K and see if it meets your requirements if you decide to go the FiiO route.
