Help Me Stuff My Lian-Li
Xoidie
Hi Im about to order this rig and was looking for some people with knowledge about the
Lian-Li PC-V2100 plus II I hope to fit all these parts in this case without having too much
cluster-fucking. I have heard this case is big for Mid Tower but wanted some insight
Thanks Alot
RIg
LIAN LI PC-V1200Bplus II Black Aluminum ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.asp?item=N82E16811112066
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813127030
BFG Tech BFGR88768GTXOC2E GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143093
PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W Power Supply
http://www.newegg.com/product/product.asp?item=N82E16817703009
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600
http://clubit.com/product_detail.cfm?itemno=A1938452
Crucial 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory X2=4GB RAM(lol)
http://www.newegg.com/product/product.asp?item=N82E16820148144
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive
http://www.newegg.com/product/product.asp?item=N82E16822136012
Tuniq Tower T-120-LFB 120mm Cpu Cooler
http://www.newegg.com/product/product.asp?item=N82E16835154001
well, I think that case is entirely unnecessary, but whatever floats your boat.
-I'd hold off on the ultra right now.
-not exactly sure what you need a PCPaP psu and that raptor HD for, but its your money.
an 8800gt (or whatever the gtx version of the g92 is, when it comes out), a corsair psu, and a seagate barracuda .10 would save you 500$ +
you can do a lot better for the ram too. enthusiast grade 2gb kits can be had for much less than 100$. corsair xms2, gskill, etc
the Ram is MIR for $54 a kit
Your post really didnt address my question
I wanted to know if all that could fit in the case
do you know any cpu heatsink and fan that will compare with the tuniq tower
but fit in the case along with the 8800 GTX ?
A lot of parts can fit inside a Lian-Li V1200.
I recommend going with this HSF combo if you want maximum air cooling, and yes it performs better than the Tuniq and should be able to fit inside the Lian Li:
Thermalright Ultra-120 Extreme HSF - $55 & Scythe S-Flex SFF21E 120MM Case Fan - $14
Also, if you're planning on overclocking, don't buy the Q6600 from newegg.com. Get it from ClubIT instead since they guarantee a G0 stepping Q6600. And if you don't know what that means, a G0 stepping Q6600 runs coolers and therefore easier to OC than the B3 stepping that you get from newegg:
Intel Core 2 Quad Q6600 G0 Stepping CPU - $280
Im not familiar with heat-sinks without an attached fan.
After I install the heat-sink where wold/do I position the fan?
:confused:
:confused:
There should be directions that comes with the HSF that'll tell how to position/place the fan.
