Help me solve my BSOD
iSkylla
Okay, so I will make this as brief as possible. Everything works fine until I use two sticks of RAM. I can use one (the RAM isn't bad) but when I use two I crash and BSOD. Unfortunately, the BSOD that I do get is very generic. It's the IRQL with 0x0000000A. Basically, it's a change in hardware. I have a feeling it is either my PSU or my motherboard. My suspicions tell me that it is my motherboard so is there any way I could test either of them? I don't have friends so that isn't an option. Is it worth changing the motherboard (I would get a cheap one as long as it were stable and could OC decently). Here are my specs
AMD X2 3800+
DFI LanParty Ultra-D
Antec TPII 550W PSU
2 GB G.Skill (Only using one stick)
eVGA 8800GTS 320MB
SB Audigy 2 ZS
2 Optical Drives
1 SATA Drive
My CPU is overclocked but that is not the issue, it happens at stock speeds also. Memtest has come out clear. Thanks for your time and all relevant comments are appreciated.
did you test both sticks individually? did you try testing them in different slots to see if a slot might be bad? are you sure it isn't the CPU considering it has an "on-die" memory controller?
Did you try another PSU? These LP boards are picky with PSUs.
How long did you run Memtest for? I would try running Memtest on each stick of RAM for at 24 hours. Some problem don't crop up until the 23rd hour.
If the new ram stick is not faulty then memory timings could be the issue.
Test the ram stick by itself, go into the cmos and see what the timings are set to.
Do the same for the other ram and make note of what is different.
You'll then have an idea of the timings worth trying for both modules.
Please be aware that you can set timings too slow as well as too fast!
It is freshly RMA'd RAM. I ran memest for 60 hours each.
The timings are default and voltage is the upper of the two options. I am quite fluent with computer hardware. You can rule out those mistakes. I think it could be a bad DIMM or something with the memory controller. How can I test it?
I have the RAM running fine in single channel mode and the computer seems stable. What would this imply as to where the problem lies? Motherboard? Memory controller?
I am guessing most likely the mem controller then. It is prolly getting too stressed with the dual channel setup.
EDIT: Are you setting it to 2T timing? I know that A64's have probs with the 1GB+ sticks of memory.
Well, it is running at 2T. I'll see if it runs stable at 1T later. I put my computer back to my old overclock. Obviously I had to change some of the memory settings, but it seems to be working fine at 2.8Ghz.
wait.. it bsod's at stock, but overclocked seems fine? definitely something strange going on with the secondary memory timings. are they all set to auto?
two other things:
what slots are you using?
what bios is on the board?
No, it BSODs at stock with both of the sticks in dual channel. One stick is fine and two sticks in single channel seems fine. It's simply when I enable Dual Channel (DIMMs 1 & 3) that I get BSODs and crashes. Now I'm running single channel (DIMMs 1 & 2) and have it overclocked. It's been running absolutely fine.
I honestly can't remember which BIOS I'm using, it's an older TMOD modded BIOS.
Try slots 2 & 4 and try flopping the mem sticks around. Them boards are very VERY finiky even though they are great for OC'n.
Any dual channel crashes. I just bought a Biostar motherboard from FS/T. We'll see how that works out.
