Help me pick a laptop
Flyers17
Well I have about 700 bucks to spend for a laptop. I want something small and portable and I want the best battery life I can get. What is the longest batter life you can get with/without wifi? Thanks in advance.
To get a decent battery life, just get a laptop with a Core 2 Duo or Core Duo CPU. Maybe Pentium Dual Cores might do. Also, don't get a laptop with a graphics card if you want more battery power. Integrated graphics is the way to go.
If you have a Best Buy or Fry's nearby, go around and scope out the laptops that they have on sale there. Usually every weekend or so, they have some pretty great deals on laptops for under $700.
But do remember that if battery life is important to you, get a laptop with the following:
- A Core 2 Duo, Core Duo or Pentium Dual Core CPU
- Integrated graphics
That should ensure that you can get the best battery life you can get.
this is what you get for $700 from BB. I would also recommend looking through the dell outlet for refurbished systems.
Another good spot to look might be DFSdirectsales.com (its dell's off lease outlet) they have some pretty awesome ultra portables there sometimes for pretty cheap.
Cool guys,thanks for the help. What is about the battery life I would get with one of these systems with wifi on. Also can you buy batterys that last longer? I have been reading about 6 and 9 cell batterys.
What are your specifications for what you are looking for?
Screen size?
Screen resolution?
Processor speed?
Internal memory?
Optical Drives?
Harddrive?
Etc.
These will all play into the battery life and how much you use it and doing what. Also, dont forget that if you are currently in school or affiliated with a university (alumi included) you can many times get discounts by buying direct from HP, Sony, Dell or whomever. Sometimes the savings isnt alot but it doesnt hurt to check.
