Help me pick a home POE GBE switch
Discussion in 'Networking & Security' started by cj3waker, Dec 3, 2017.
  1. cj3waker
    cj3waker 2[H]4U
    2,491
    Oct 12, 2010
    Just moved into a new home that we are going to be in for a long time, and I'm going to be plumbing some ethernet. Looking for recommendations on a good switch. Will be used for normal networking of PCs and my home server, and POE IP cameras. A 24 port should more than cover me.
    Needs:
    All ports GBE
    All ports POE
    Doesn't need:
    SFP ports
    Fancy uplink ports
    Nice to haves:
    Good UI
    Drive attachment for media or camera storage
    software/UI for the media or camera storage
  2. cj3waker
    cj3waker 2[H]4U
    2,491
    Oct 12, 2010
  3. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,703
    Jan 1, 2008
  4. thrash408
    thrash408 Limp Gawd
    280
    Jan 22, 2010
    Check out Ubiquiti. I got a 24 port for around 300 bucks, run IP cameras, APs, and about 15 drops. Sits in the garage, which can get hot as hell and still runs strong!
  5. bman212121
    bman212121 [H]ard|Gawd
    1,512
    Aug 18, 2011
    Well I don't think you're going to find anything much cheaper than the $300 switch you linked. (It's an old switch, otherwise the new equivalent of that is easily over a grand) POE costs serious money, and if you really don't have a lot of POE devices you might be better off getting a separate switch dedicated to POE and using a smaller switch. You can buy an 8 port POE switch and a 16 port switch for less money than a 24 port POE switch. (Probably not something you want but making the suggestion anyway) The other thing to keep in mind is that not all POE switches are created equal. While all of the ports can be used as POE, there is a limit to the total power draw the appliance can support. Several vendors will make 2 different models of the same switch, one with a larger power supply than the other. There is also POE+, so if you have larger PTZ cameras or some of the more exotic toys, it might be a consideration. (Probably not in your case) A couple more points, you didn't say if you need management, but POE kind of implies that, and I'm not sure if you can get a 24 port POE switch that won't do VLANs.
  6. alienb
    alienb Gawd
    754
    Jun 10, 2004
    This is only 10/100 on the PoE ports. The only gigabit ports are the uplinks.
  7. cj3waker
    cj3waker 2[H]4U
    2,491
    Oct 12, 2010
    Well that will not do, Leaning towards the refurbed netgear
  8. Skillz
    Skillz [H]ard DCOTY 2017
    20,206
    Aug 14, 2004
    Are you sure about that? The web site says they're 10/100/1000 ports and there are 24 of them. It says the uplink ports are 10GBE ports. Even Cisco's web site confirms that.
    klank and bman212121 like this.
  9. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,440
    Dec 23, 2001
    I second Unfi stuff. If you stay with them from APs, Switch, Router, Camera etc everything is nicely integrated :)
  10. grasshoppa
    grasshoppa Gawd
    573
    Jun 18, 2017
    Thirded. Their switches are reasonably priced for what you get, and you get a crap load. Not to mention that if you stick with unifi gear it all integrates nicely.
    The management interface ( unifi controller ) really puts it over the top for me.
  11. Machupo
    Machupo Gravity Tester
    5,269
    Nov 14, 2004
    Fourthed (is that a word?). Just got a basically new unifi 24 port 500w poe on ebay for cheap. While I have a pf sense box for my main ips, the lab setup, all of my switches, and my aps are unifi, so it is a snap to do deployment / review logs / etc.
  12. Valnar
    Valnar [H]ardness Supreme
    4,241
    Apr 3, 2001
    I'd get a Cisco small business switch, like the SG200 or SG300 if you want routing.
    Drive attachment? Perhaps you're thinking of one of those all-in-one-Linksys-router-firewalls-with-usb-NAS-kitchen-sink things.
  13. airtron
    airtron n00bie
    1
    Jun 22, 2012
    I run all Ubiquiti and love it. I might even replace the pfsense with their USG.
  14. thrash408
    thrash408 Limp Gawd
    280
    Jan 22, 2010
    I did, no problems at all. Even does deep packet inspection
