Toasted Nanners
- Jun 18, 2004
A neighbor of mine somehow ended up with a set of old Dell 2.0 speakers (I did a quick search and they look like the A215s) but no power cable. I told her Id try and find something that would work for her, but I dont know enough about this stuff to be confident I wont accidently give her something that is incompatible. Could anyone give me an idea of what specs I should be looking for to make sure I dont blow up this poor womans speakers? (The port on the back of the speaker says DC IN 12v)
I dug through my box of random cables/other electronic junk and came across an adapter with a sticker that reads:
Direct Plug-In
Class 2 Transformer
I/P: 120V AC 60Hz 9w
O/P: 12V AC 600mA
But I suspect the fact that the output is AC rather than DC may be a problem is that correct?
Thanks in advance for any help.
Direct Plug-In
Class 2 Transformer
O/P: 12V AC 600mA
