Help me for choosing casing and sata raid card
shetu
My boss will go USA in June. So I give him some money and he will buy a case for me. So pls help me to chose a good server casing for storage server next 3/5 years. I need pc shop address (Seattle) too.
Storage server, rendering 3ds Max seens
500-600$
3) Where do you live?
Bangladesh
Casing (4 or 5 unit rackmount), if possible any cheap sata raid card
GIGABYTE GA-X58A-UD7 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Core i7 (LGA1366)
Ram 4GB
Power supply 800w (Gigabyte Odin Pro GE-M800A-D1.)
6) Will you be overclocking?
Not yet
2x Philips 21.5
June
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
no need
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Winxp 32bit
Is it good case?
20 bay
http://www.newegg.com/Product/Product.aspx?Item=N82E16811219021
24 bay
http://www.newegg.com/Product/Product.aspx?Item=N82E16811219038
I highly recommend that you wait until late May or early June and ask this question again. A lot can change between now and June.
What 1000W PSU do you have? Find that out as that's gonna determine whether or not it would be even a good idea to build this server.
Oh and both those Norco cases are good. So is this one:
$350 - NORCO RPC-4220 4U Rackmount Server Case
The key difference between the Norco 4220 and 4020 is that the 4220 uses five SFF-8087 connectors to connect all 20 hard drives to the PC. The 4020 will use 21 SATA connectors to connect all 21 drives to the PC. So the 4020 route would be the messiest in terms of cable management but the cheapest in terms of getting additional cables as the 4220 route would require you buying 4 to 6 SFF-8087 SFF-8087 to Multi-lane SATA Forward Break-out Cable at around $15 each.
Yeah you can go with that case.
No you don't need to replace the PSU
