Help me find a transcoder~!
UnknownSouljer
Well I'm looking for a transcoder to go from component to VGA. The application will be home theater equip/gaming systems (though a receiver of course), to a 2005fpw which as we all know very well doesn't have component input. It does have VGA though and that also is capeable of taking a HD signal (720p in this case) so with that I know what I need.
Anyway, I found this on Ram electronics:
http://www.ramelectronics.net/html/kd-ctca2.htm
Love it. Problem is the price tag. I did a quick check on ebay rendering basically arround the same price. Is there a supar sekret webpage with similar products for less money (must allow high resolution passthrough, must de-interlace)?
Anyway, any help in this matter would be appreciated.
http://www.vdigi.com/
VD-Z3 Component -> VGA Transcoder
$59
Progressive Scan 480p, 720p, 540p / 1080i
2 In 1 Out (YrPrPb In & VGA In; VGA Out) with switching
XBOX, GC, PS2 HDTV Output Supported, P.Scan DVD player, & HDTV cable receiver.
High compatibility for CRT, LCD monitors
Auto signal detection.
Easy configuration
Brightness adjustment
Review:
http://hardware.teamxbox.com/articles/xbox/934/VDigi-Electronics-Enhanced-VDZ3-Review/p1/
Looks nifty. The only way to make it more perfect (for my uses) would be to have dual component input and single vga output, but I can see why for most people this particular setup is optimal.
Edit
nm, almost forgot you were using a 2005fpw, which runs a higher resolution.
