Help me finalize my decison for 24"
Boardin087
Looking to get a 24" LCD. For gaming mainly, some movie watching and definatey ps3 gaming. Have a FHD2400 sitting in my bedroom right now, returning it because of BLB issues (dont have them but not risking wanting them, plus a stuck pixel anyway) and no audio output (unless I spend 50 dollars)
Looking for HDMI/DVI inputs
Sound outputs(for the HDMI since my ps3's sound will be going to it)
1:1 scaling (actual scaling, dont wanna lose part of the screeen)
1900:1200
Some perks
Cheap! I spent 480 with tax from bestbuy and would like tos pend lesss, which means taht 500 dollar samsung/lg/25.5inch westy/HP are likely out of the picture, unless someone can convince me its actually worth it.
Able to buy at a B&M, this is the only thing stopping me from buying the Benq G2400WD
USB ports
PIP
tucks me in at night
I have been looking at (the problem)
Benq G2400WD (not available B&M)
FHD2400 (Sound output, BLB, slower then 3ms response G2G)
Acer P243WAid (cant see at a B&M, doesn't scale 1:1 supposedly)
Acer P241 (can see at a B&M, doesn't scale 1:1)
Some monitors I need more info on
LG W2452T (500$)
Samsung 2493HM (500$)
Westinghouse 25.5 L2610NW (500$ but its bigger)
Soyo at Microcenter 24" (cant find any info on it, link is here http://www.microcenter.com/single_product_results.phtml?product_id=0287410)
I'm sure I missed some but I have been doing some research and really cant figure it out!
I would remove that Westinghouse from your list. I've heard about problems using it over HDMI with PCs even though strangely enough they include a DVI to HDMI cable with it as well as VGA.
If you can find the L2410NM I would consider that better.
Regards,
10e
Regards,
10e
Thanks I'll look for that 24 but I doubt ill find it. Any other input? I see you post alot here :)
