im a little confused as to what you want
are you trying to build a new comp or simply upgrade an existing one?
option two is clearly superior, im unsure why anyone would buy anything but C2D atm
Your current system is still good. Unless your father needs a new pc now, I'd hold off for a while, at least until around Q2'07. This way, you'll be able to get an even better CPU for your money (new core2's will be out, along with core2quad), and most likely a better vidcard (since the R600 and lower end dx10 cards will be out). Regardless whether you build it now or later, get the c2d for yourself and give your father your 4400+. You should be able to get more juice out of that 4400, though (like around 2.8Ghz).
To keep yourself under budget, you could go for an nF 650i SLI solution instead of 680i SLI. What's your current monitor size? Unless you have a 24" or larger LCD, you really don't need SLI at all, and its not that great of an upgrade path. I'd suggest goin with a P965 board, to help keep you inside your budget (the Gigabyte DS3 or Asus P5B-E come to mind).
The Firestix memory is higher quality, and better than the GSkill ram in my price range.
