AnNiMosSiTY
- Jan 1, 2001
This is a pc for my wife to get her started on WoW, only thing else it will be used for is browsing and watching movies.
Nothing set in stone but being a budget build I'd like to keep prices as low as possible.
US, Sacramento CA. Have Frys and Best Buy locally.
Motherboard, Video Card, Ram, CPU Cooler.
I already have an I3-3225 CPU, 550 Watt PSU, Case, 256GB SSD, and 1TB Storage Drive.
6) Will you be overclocking?
No
1920 x 1080 21 inch and a seperate 1920 x 1080 37inch westinghouse for movies.
ASAP, before xmas.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
usb 3.0 and sata 6gbs, sli is not needed.
yes win7 64.
I need to know what components you would recommend to finish this build with what I have and possibly taking advantage of any cyber monday or upcoming deals. Not sure what motherboard to go with either, this rig will not be overclocked at all. I will possibly add a sound card to the mix later that has a headphone amp as well.
No
ASAP, before xmas.
yes win7 64.
