Hi everyone.
I currently own an 22" LG L226WTQ LCD wich I've owned for about 2 years now.
But the thing is that eventhough the quality of the monitor is nice, the size doesn't impress me and I need to feel the "wow" factor once more (last time I went from 17" to 22").
Wich is why I would want to move on to a bigger monitor (and yet not too big so I can carry them around often - need 2 so both me and my wife will have one).
I've been looking online for hours trying to figure out the technoligy but I can't figure out what happens if you combine those technologies.
From what I read 27" might be the best choice in terms of getting a descent dpi quality (I don't want to downgrade too much from the quality I allready have on my 22").
Keep in mind that I only use my pc for gaming, googling and rarely for photoshop (I hate ghosting and slowing wich I sometimes have now with the current screen at dragonage 2)
Also I would love to find a screen with 120 Hz since I can see the refresh rate under 75Hz and it annoys me, I did notice that with my old CRT of phillips wich broke down, had 200Hz and the mouse cursor moved faster with less hand movement, the screen was a lot easier on the eyes and I had less glitches while in game.
Now I have 7 questions wich I was hoping you guys & girls could answer me.
1) Is 27" realy the best choice or is it more like 26" or 28"? I can't tell for sure, but I want the change with the size I have now to be significant (and as I stated before, not too big to carry).
2) Would you advice LCD or LED?
3) I read something about 1920x1080p being the best res for HD quality but at the same time I read that eventhough 1920x1080p is better then 1920x1200p, having a screen with 120Hz refresh rate would actualy make 1920x1200p better. Is this true?
4) I read that you can actualy start to notice ghosting more easily if your monitor is 5ms and up when you are using high resolutions as if the monitor lags because it can't follow up on the frames, is this true?
5) I read a lot about 3D monitors these days but I don't want to have to buy and wear 3D glasses and worry about not losing them... and almost every monitor sais 3D these days. So how can I know wether you need shutter glasses or no glasses at all?
6) From what I can tell IPS and TN panels don't have much advantage over one another since IPS has a better vieuwing angle "BUT" is expensive and slows down reaction of the screen, is this true?
7) Would you be able to mention as much monitors as you can that fit my description or come close to what I want?
It took me hours to find 2 released monitors (3 others weren't released yet) but I forgot to store the links and can't find them in my history (too much hours of googling to find the links)..
So I was hoping you could help me retrieve them or possible make me aware of other monitors (I only know about 1/3rd of the manufacturers)
Sorry for spelling errors in advance (didn't have time to double check).
