Help me choose a MOBO
vidoprof
Not sure where to post this really but.
I am looking at getting either the Q6600 or E6850 when the price cuts happen. I don't game and I don't plan on OCing at all. I keep my computers for around 3-5 years. I have a AMD 2100+ still so that tells you something.
With this in mind and the fact that I don't plan on OCing or gaming what motherboard do you think I could get away with for pretty cheap.
I will use onboard Lan, audio, and get a cheaper video card. I need an IDE (at least 1) channel and I dont have any parts at all right yet.
Any suggestions. I see people recommending the DS3R, but that might be a little much for me, $150, and not really utilize the thing.
Thanks
Ryan
I suggest the Abit IP35-E, which you can get for about $110. It uses the new P35 chipset, so the E6850 will be supported if you do plan to go that route. And Abit has a good history of making good motherboards.
I hear I should get the P35 chipset does this really matter?
thanks for the suggestions guys
Ryan
Get a 650i Ultra board for <$80 after rebate. You will never make use of any of the extra features of the P35 boards, they are not magically faster, and in short, there is zero reason for you to buy one unless you need to connnect more SATA devices than it will support. If so, get the Abit IP35-E.
The p35 boards do have a pretty good memory controller that doesn't seem to have any issues with 4 sticks of RAM. That's a good reason for me to buy one personally. The 6 SATA ports on the IP35 (non-E) are also appealing. The OC's on the P35 are somewhat better than the 6XX series and 965 boards. So I wouldn't say that there is zero reason to buy one. But the 650i board is a good value also.
I was looking at the Gigabyte DS3 also. I know it's a little more, but can you guys pit a couple against each other and let me do some research.
thanks
Ryan
thanks
Ryan
If you're going to get a DS3, get the P35 version, not the 965. The 965 is good, but for the extra $15 or so, the P35 is better.
still don't see anything wrong with the mobo that I recommended earlier - it's an Intel P35 mobo with 1 IDE channel, RAID & firewire for $110.
Sure it probably won't have an oc BIOS but you say that you don't need that & Intel brand boards are usually reckoned to be about as solid as they come.
Think that I'll go back to recommending abits :p
