Umm... the 7900gs and x1950pro are better than all those cards and are going for $130-$140 AR
rebates mean nothing to me.
decided on going with http://www.newegg.com/Product/Product.aspx?Item=N82E16814145140 after thinking it through.
i found this 8600gt http://www.newegg.com/Product/Product.aspx?Item=N82E16814121068
looks good to me....how about you guys?
If you want to be underwhelmed, go for it. It is slower than 7600gt and MUCH slower than the 7900gs or x1950pro in dx9. The only thing you would possibly pick that card for is the HD video encoding. DX10 games aren't even out yet and when they start rolling out en masse, you'll want a MUCH better gaming solution than what the 8600gt can offer.
