Hi every1,
I am about to upgrade my rig to a liquid cooled. Since this is my first time building one, there are a lot of stuff i do not know or sure about.
Here is my current system spec:
Cosmos 1000
i7 920 D0 @ 4.0 1.22vcore with HT on, 48-50C idle, 58-61C loaded, on air.
( The AC vent is on the floor in my room, in the corner, so I put the case right on it. The 920 at 4.0 runs 28-32C idle. 40-43C on load, LOL.)
rampage 2 extreme, i7
2x GTX285 vanila (will be cooled with koolance full coverage blocks)
cooler master real power pro 750w
4x Noctua NF-P12 120mm fans. 54CMF (1300RPM)
I will be liquid cooling the cpu and vid cards.
I have bought all the water blocks for them. (swiftech apogee GTZ i7, Koolance GTX285 block)
My question:
1. Will a MCP355(DDC3.2) w/ XSPC reservoir top + Thermochill PA120.3 + 1/2'' ID tubing handle this setup, namely an OCed i7 920, 2xGTX285. If no, which one might be the bottleneck? the pump or the rad. If yes, can I add an NB/SB block into the loop? That makes the system 4 blocks, which is highly restrictive. ( My case is a cosmos 1000, the biggest rad i can put inside is a 3x120mm on the roof. And the case's top is not flat, so i cant really put another rad on it, plus its gonna ruin the looking)
2. Will my PSU enough for this whole system? (cooler master real power pro 750w continous, 900w peak. 76A on the 12v rail) How much watts does a WC system usually need? The MCP355 is about 18w. is that it?
3. Can I fill car coolant into the WC system??
Thank you for everyone for answering
Updates:
I have mount the PA120.3 on the inside roof. But it really does not fit well. Only 4 screw holes on the rad match the case, which is only 1/3 of the rad. But it seems steady.
The PA120.3 is too thick. After adding the fans, its already touching part of the mobo but seems to be fine.
Cosmos 1000
My question:
Updates:
