Hello, My brother has a budget of $500 and wants to be able to play BF2 and Css without lag and just wants a decent gaming computer.
Gaming, School work
$500(Not including tax or shipping)
3) Where do you live?
Greenwood IN
CPU, MOBO, GPU, RAM, PSU, CASE, HDD, everything for a tower case.
None
6) Will you be overclocking?
Maybe
A crappy one now but will be upgraded to a 1080P monitor. So it needs to be able to handle that res.
In september his birthday so before then but that would be the general area.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SLI/Cross fire support
Yes we will be using Windows home 64bit.
But one of my friends is selling...
Intel Q6600 2.4 GHz CPU
EVGA nForce 780i SLI FTW
EVGA GeForce GTX 260 Core 216 Superclocked - 55nm
Corsair Dominator 8GB (4 x 2GB) 240-Pin DDR2 1066 (PC2 8500) Dual Channel Kit Memory
Coolmax CUG-950B 950W ATX12V V.2.2 SLI Certified Modular Power Supply
All that for $385
Do you think he should jump on that? or build a diffrent computer with newer parts?
This is what i was looking at.
MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131647
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130567
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145324
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
Windows 7
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Thats like 750 or so before rebates though...
Gaming, School work
Greenwood IN
None
Maybe
All that for $385
MOBO
CPU:
GPU:
HDD:
RAM:
PSU:
Windows 7
