My budget is around 10.000$
I am planning to build a very high-end pc, mostly for gaming.
I do need help in builiding it, starting from the case selection going down to the details, peripherals and so on..
Please provide as much answers as you can, especially regarding the peripherals.
Please provide as much details as possible.
Screenshots:
My plan was a gpu sli composed of 2 high-tier gpus and a custom liquid cooling system.
I'll post a few screenshots showing some moddded pcs I like:
570x dual gpu: http://hexus.net/media/uploaded/2016/11/824d4b43-ff8f-4...
570x + ll120 fans: https://cdn.pcpartpicker.com/static/forever/images/cont...
570x + ml120 fans: https://www.overclock.net/photopost/data/1655111/4/4a/4...
570x + custom liquid cooling: https://www.scan.co.uk/images/products/2902162-b.jpg
570x insight on cusom liquid cooling: https://linustechtips.com/main/uploads/monthly_2018_04/...
anidees AI crystal timelapse mod: https://i.ytimg.com/vi/o7i6DSCKNA0/maxresdefault.jpg
General questions:
1. Will a middle-tower case, like the "Corsair 570x crystal", be spacious/wide enough to sustain such a build? (I showed some pictures with dual gpu build and liquid cooling, but it looks very narrow).
1b. If not, I'd like to pick the "anidees AI Crystal", which is a full-tower case that looks incredibly good to me, but I never heard of the "anidees" company before.. are they trustable/reliable as sellers?
1c. Will there be any compatibility problems with the 11xx series?
2. Should I wait for the 1180 series to be released or should I get 1080 ti instead? I just read that 1180 will probably be mounting GDDR6 memory, which may be far better than the current GDDR5 mounted by most gpus. I wouldn't care about a 20% performance increase, but I fear that this may be a little "gap" in the gaming world.
2b. If yes, what can I get as a substitute in my build? I was planning to get a 1050 Ti.
2c. What about the custom liquid cooling system? I am gonna ask a local shop to build it (I'm not good with pipes and stuff). If the clcs (custom liquid cooling system, from now on "clcs") is planned for a single gpu how much tedious is to change it to fit 2 gpus (2x 1180)?
3. Is a 1000W PSU enough to power this machine?
3b. If not, how much power is needed?
3c. Should I invest some more money to get a "Titanium" certificated one, or is a "Platinum" enough? (Consider I plan to power off my pc only to install updates and for maintenance)
3d. Is an RGB PSU a nice addition to the customization? (it doesn't look very bright to me)
4. Should I get a top-tier cpu? (threadripper or i9)
4b. Will I experience any increase in performances running one of those cpus? (Consider gaming, 3d modeling, 3d rendering)
5. Do you think Corsair ML120 PRO RGB looks bad compared to LL120 RGB? I do, and thus can't decide.
6. Do you think 4TB are enough as an archive storage?
7. Do you think that Gunnars (gaming glasses) may be useful?
Detailed questions about components/peripherals:
A. Corsair 570X Crystal vs anidees AI Crystal - which one is better, and why?
B. Ryzen 7 2700x vs Intel Core i7 8086k - which one is better, and why?
C. Ryzen Threadripper 1950x vs Intel Core i9 7980XE - which one fits my build the most, and why?
D. Samsung 970 EVO M.2 vs. Samsung 970 PRO M.2 - which one is better, and why?
E. Corsair ML120 PRO RGB vs Corsair LL120 RGB - which one is better, and why?
F. Seagate Barracuda Pro 7200rpm 10TB vs. Samsung 860 EVO SSD 4TB - which one should I pick, and why?
G. Corsair K95 Platinum vs any other valuable gaming keyboard - which one is better, and why? (make suggestions, please)
H. Razer Naga Trinity vs any other valubale gaming mouse - which one is better, and why? (make suggestions, please)
I. Asus PG27UQ vs Acer Predator X27 - which one is better, and why?
Looking for:
I. A pair of "over-ear" headphones.. They must be "over-ear" because my ear suffer a lot from wearing "on-ear" ones. I'd like them to be bluetooth or wireless.
I found this one, are these good? https://www.amazon.com/gp/product/B00L6S6XWO/ref=ox_sc_...
II. A gamepad (actually 2) to play some offline games.. Scufs are way overexpensive, and considering I won't be using them much I don't think I'll be getting one. XBox One original pads are really expensive, but I do like the design and ergonomics.
I found these ones, but they are even more expensiven (but with a cool design): https://www.amazon.com/gp/product/B076ZC7KQM/ref=ox_sc_...
Could you please suggest me a good gamepad (cabled or not)? RGB would be great, but I don't really care much about the pad..
III. An external sound system. I was looking over "soundbars" which seems pretty solid. I found Razer's soundbar: https://www.amazon.com/gp/product/B00PK2POOU/ref=ox_sc_...
Looks good to me because it has an external subwoofer aswell. If you were me, which one would you choose? Please provide me suggestions about good external audio systems (not necessarily soundbars).
Thanks everyone, your opinion means a lot to me.
Roberto
Screenshots:
General questions:
Looking for:
Roberto
