uss enterprise
- Feb 5, 2009
Hey all,
I have a friend who wants a new AMD based system. Only AMD, doesn;t like intel at all. Dunno why.
His budget is 500-600.
Usage is lots of web browsing, and casual gaming. Nothing too intensive, but he is a HUGE WoW (world of warcraft) player.
His previous system consists of:
Unknown MB
Athlon XP 1300+ processor
1 gig ddr 333 memory
AGP x1650 Pro 512MB video card
80 gig 7200 rpm 2 meg cache IDE HD
As you can see, he's been using it for years, and the same needs to be expected of whatever I build for him. Should last maybe 5 years.
I was seriously considering the XII 720 trick to run a cheap quad for him, but due to his reliability requirements, don't want to risk it. So i'll probably get him an XII 940. Not necessary for him, but in a couple of years it will be required. So due to his longevity requirements without putting money into it, I need to get him set up now. So a 940 seems in order.
RAM - I'm getting him 4GB of DDR2 800. Corsair likely, because it's my personal preference, and i'm building it, so....
HD, I have a bunch of new SATA WD 250GB 8meg cache drives sitting in a drawer that I never ended up using, so i'll toss him 1 or 2.
MB - Here's where i'm stuck. I'd like a good gigabyte board, he doesn't need, and will likely never need, dual video cards. In fact, he may not need any, if the onboard video is good enough. How would a board with the ATI 3300 integrated video compare to his old AGP format X1650 pro 512mb? I've heard good things about the 3300 integrated video, and I know his card is old, but find it hard to wrap my mind around an integrated chip being better than a dedicated card. (and i'm not worried about the hit on system ram for the integrated video, it's still a huge upgrade from the ram he had)
Think the 3300 integrated would be better than what he had?
I need enough left over for a supply, Sata dvd-r, and misc stuff, so if he NEEDS a card, it may hit the proc/mobo budget a little. (dual instead of quad, and cheaper board instead of one with raid, 128mb sideport for video, etc....)
Or if anyone else has any other ideas or configs, let me know.
Thanks!!
Unknown MB
Thanks!!
