thevelourfog
- Apr 6, 2005
Will host a "BIM Cloud" with 4-6 Virtual Machines for the architecture firm I work for. Users will be doing AutoCAD, Revit, Photoshop primarily. Clients will use old (or cheap) PCs to connect to this local server hosing the VMs. It's all going to be setup by another company. Infrastructure won't be a problem.
About 5-6k
3) Where do you live?
Southern California
A single 4 or 6 core Xeon over 3 GHz (must have hyper-v), A DX10+ video card with remote fx, SSD RAID-0 (3x 128GB or 2x 256GB), at least 48GB RAM, Rack Mount Case, Redundant Power Supply, Any misc hardware such as rails for the case, DVD, ect.
None
6) Will you be overclocking?
No
N/A
A month maybe?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
(Intel) RAID, Dual Intel NIC (one for VMs, one for SAN with iSCSI)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 7 Ultimate will be used for this machine and clients.
It's an unusual machine I guess, but my boss has it in his head that this is a better solution than individual workstations and wants to give it a go. It would likely be cheaper to buy/build i7 machines for individual users...
About 5-6k
Southern California
None
No
N/A
A month maybe?
