Help me build a new budget system.
I need help. I've been surfing newegg, zipzoomfly and tiger direct all day trying to piece together an upgrade and I'm totally lost. I don't have a clue where to start so here's the story. I want to upgrade the cpu, mobo and memory of the pc in my sig as far as $350 will carry me. It is definitely a "budget" upgrade but I figure anything is better than a celeron and a mobo only has pci slots. Yes, you heard right, I dont even have an AGP slot. I would like to try AMD 64 and have the option for a pci-e video card in the future.The mobo should have onboard video if possible since I dont have a video card right now. I guess I could try and squeeze in one of those $35 pci-e cards if need be. I also would like suggestions on the best black, decent looking case and ps combo I can buy for $100. I really like the coolermasters like the centurion series. The total budget is $450 for case and components. Thanks so much for your help.
Hey Aratech I just posted a $500 budget system that I built for my friend for someone in this thread
http://hardforum.com/showthread.php?t=1036493
Since you just need the mobo, CPU, and RAM, you can get the AMD Athlon 64 3500+ Venice and Biostar Tforce 6100 board combo
for $250 (it should subtract $20 once you add to cart)
You can actually keep the RAM since its DDR. You can get the case I suggested, which is the Antec SLK3800B w/ Smartpower 400W PSU for $80. Another option since your budget is $450 for everything you can used the rest of the $ to get a one of those cooler master cases that you like and a forton source 400W power supply(im not sure which one if best for you but maybe someone in the power supply forum could help you out)
The onboard video is probably better than a cheap $35 card, and you can just add a good PCI-e card later on when you have more $. Hope I was able to help you a little bit.
I will be ordering my components this weekend. These are the parts I'm buying unless someone objects.
1 COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel - $43.99
1 Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply - Retai - $68.99
1 pqi POWER Series 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) - $68.99
1 AMD Athlon 64 3500+ Venice 1GHz HT Socket 939 Processor Model - $278.00
1 BIOSTAR TForce4U Socket 939 NVIDIA nForce4 Ultra ATX AMD Mobo Retail - Combo^
I already have these parts:
Windows XP Pro
DVD-Ram drive
Maxtor 200gig harddrive
Creative Audigy soundcard
PVR-150 Tuner
NIC
Artic Silver
This should be enough to assemble my new box. Let me know if I missed anything and if these parts are all compatible. I'm especially concerned about the mobo and power supply working together. I dont know anything about the new connectors, pins, rails and all that other stuff. Also let me know if you see somewhere I can save money. Thanks.
Come on guys, I need some advice here. I want to be sure about this before I shell out my hard earned cash. ;)
if you are comfortable with overclocking, then you can get a 3200+ or 3000+ venice instead.. you can also get an opteron 144 or 146 s939..
both the san diego and the opterons have 1mb cache instead of 512kb.
i also think that a 3700+ san diego core is about $200.. let me see
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539 $212
http://www.ewiz.com/detail.php?name=A64-3700CF
http://www.ewiz.com/detail.php?name=A64-37CFBX
opteron:
http://www.monarchcomputer.com/Merc...ode=M&Product_Code=120331&Category_Code=amdop
http://www.monarchcomputer.com/Merc...ode=M&Product_Code=120330&Category_Code=amdop
http://www.ewiz.com/detail.php?name=OS146BNBOX
http://www.ewiz.com/detail.php?name=OS144BNBOX
this motherboard will save you $ http://www.newegg.com/Product/Product.asp?Item=N82E16813138264 it may not oc as well.. there are plenty of nforce4 boards out there too..
^^^^Sounds good. So how much difference will the extra cache make in the San Diego 3700 vs the Venice 3500? I ask because It would run me about $30 more if I went with the San Diego due to price and the loss of the biostar combo discount.
And what's the difference between the Opteron and SanDiego if they both have 1mb cache?
How would the Opteron 144 @1.8ghz compare to the Venice 3500 @ 2.2ghz? Would the extra cache compensate for a lower clockspeed? If I went with an Opteron 144 I would still spend the same amount that I'm spending now even after the loss of the biostar combo discount.
I guess I'm confused about what's more important, speed or cache. I've noticed that intel chips have higher clock speeds but less L1 cache.
if you are not going to overclock at all, then a 3500+ venice would be faster than a 144. the reason people buy the opterons is because they overclock very well. A san diego and optern 1xx are basically the same.. the opterons go through more stringent testing and have a different IHS, which is the metal thing on the top of the cpu that touches the heatsink and protects the core.
so it really depends if you think you will overclock or not.. the extra cache can kinda be the equivalent of 200mhz.. so a cpu that is 2.2ghz and 512kb cache would roughly equal one that is 2ghz and has 1mb of cache..
i personally would get the cheapest opteron i could get my hands on and overclock it.. but that's not for everyone.. that venice will cost the same and be 400mhz faster though.. so if you are leary about overclocking, then it might be smarter to get that.. or maybe the 3700+ san diego is worth the extra $...
I sent my order to new this morning.
I went with the Venice 3200+ and the asus mobo. I only plan to oc to about 2.2ghz just to be safe. I'm sure it's possible since Ryan Shrout over at PC Perspective was able to reach 2.8ghz on the standard 1.4v voltage and with standard AMD air cooling. If I at least do 2.2ghz and match the 3500+ then I will have saved $50 .
Good choice - you won't be disappointed with the 3200+ and it will easily oc beyond 2.2 once you get comfy with overclocking the Athlon 64.
