horrorshow
Lakewood Original
- Dec 14, 2007
Price/Performance for Litecoin mining is going to be its sole purpose.
We are planning to build 10 boxes total etc.
So, all recommendations are welcome. Please try to keep the price per box to under $1200 if possible, but $1500 is doable.
Thanks as always [H]
Litecoin mining, exclusively.
$1,200 to 1,500 tops (tax/shipping included) - Price/Performance is of utmost importance
Dallas, TX
A complete box. CPU/Mobo/RAM/Video card(s)/HD/PSU/CASE
None.
6) Will you be overclocking?
If beneficial, yes.
Irrelevant.
Within the next 10 days.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Crossfire support for mining. Other than that, standard feature-set should be sufficient.
Yes, Windows 7 64-bit.
Dallas, TX
None.
If beneficial, yes.
Irrelevant.
