xanvincent
- Aug 6, 2009
Hello [H], long time lurker, first time poster.
Anyway, I'm looking to build a lan box for college/lans. My only requirement is light and/or portable. Preferably quiet. This will usually be sitting on my desk, next to a 22in widescreen monitor, so it does need to be small. I will be building this from scratch so all major components will be considered, peripherals are already set in stone, I know what I like to use in that department.
As far as budget, I AM a college student so cheaper is better. I'm thinking ~$600-700.
The case needs to fit a 4850 or 4870. I was thinking a Lian-Li V351B but part of me thinks this may be too big. I've even considered HTPC cases (putting the monitor on top of them) but PSU is usually an issue here.
Processor will definitely be AMD, deciding between the PII x2, x3 or x4 because of heat. Cooler for this is still up for grabs, Gemini II maybe? I will overclock.
PSU needs to be modular and of good quality.(for those that dont know, this includes Seasonic, Corsair, PCP&C)
Your suggestions please, [H].
