MrQuickness
- Jul 14, 2010
- Gaming, web browsing, school work, multimedia.
- About $600, with tax and shipping. The cheaper the better.. I'm mostly looking to get my bang for the buck.
3) Where do you live?
- California. I live a couple minutes away from a Micro Center and Frys, so I'll mainly be purchasing from these places (and Newegg of course).
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
- Motherboard, Processor, Video Card, RAM, and Power Supply.
- I'm going to re-use my old case, hard drive, optical drive, and monitor.
6) Will you be overclocking?
- Nope.
- I have an 23" Acer H233H (1920x1080).
- Within the next month. I might stall a bit and wait for Black Friday, though.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
- Crossfire/SLI support for future upgrades would be nice, but it's not a requirement. A more future proof motherboard would be nice as well.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, I have an extra copy of Windows 7 64-bit.
Here's a build I quickly put together on Newegg:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=14484112
$79 ASUS M4A77TD AM3
$89 AMD Phenom II X3 740
$169 Gigabyte GTX 460
$82 G.Skill 4GB (2 x 2GB)
$69 OCZ ModXStream Pro 600W
= $490
I also made a similar build at Micro Center for $480 (AR):
http://www.microcenter.com/single_product_results.phtml?product_id=0337970
http://www.microcenter.com/single_product_results.phtml?product_id=0317772
http://www.microcenter.com/single_product_results.phtml?product_id=0344331
http://www.microcenter.com/single_product_results.phtml?product_id=0341976
http://www.microcenter.com/single_product_results.phtml?product_id=0334767
Are there any changes that I should make?
- Nope.
= $490
