Blueduck577
- May 11, 2007
Hi guys, I have been out of the comp building loop for a long long time...
I would like to spend less than $400 on a new desktop system and peripherals, minus the OS/software, monitor, and speakers. It will be used mostly for MS office and heavy surfing. I probably may watch some movies and do minimal photoshopping.
I won't be using it for CAD or gaming though, I have another comp for that.
Anyways, do you guys have any builds to suggest or have built something similar in the past that I can grab the partslist off? I would like to buy everything off newegg if possible, I've used them in the past and haven't ever had any problems.
Thanks!
Thanks!
