DragonNOA1
- Aug 15, 2004
I want to backup a Windows 2000 desktop that a business has put all their important software on (they said it was cheaper than buying a server OS). Anyway, I was looking at Acronis, which looks good, but also wanted to compare Backup Exec and there are literaly hundreds of versions. Can anyone recommend me a version or their experiences with either software?
Also, they will need to take those images away from the business at night. With backups being a max 80GB, can anyone recommend a backup solution that can easily be taken home, like DATs or DLTs (preferrably links to products) that you have used or that would work good for this situation?
Is there a budget for all this? Probably $500 dollars for software and hardware, but I'm sure it could be squeezed upwards a little.
Thanks for your help.
