Help making internet, email, picture pc
UberPooner
Ok, so im building a computer for my dad. He is just going to use it for email, pictures and internet so nothing to "hard". anyway ive been looking at the parts below. I was wondering if this would all be compatible with the mobo i picked out. also would you guys make any suggestions on what to change or add?
Oh also, you guys think 380w is enough to power this beast?
COOLER MASTER Centurion (comes with 380w psu) http://www.newegg.com/Product/Product.asp?Item=N82E16811119078
Western Digital Caviar RE WD1600YS 160GB 7200 RPM 16MB http://www.newegg.com/Product/Product.asp?Item=N82E16822136062
GIGABYTE GV-NX73T256P-RH GeForce 7300GT 256MB http://www.newegg.com/Product/Product.asp?Item=N82E16814125036
GIGABYTE GA-945P-S3 http://www.newegg.com/Product/Product.asp?Item=N82E16813128015
Intel Pentium 4 541 Prescott 3.2GHz http://www.newegg.com/Product/Product.asp?Item=N82E16819116231
And i think thats it.
If thats all he's doing, then all he really needs is a celeron. If you want the system to last alot longer, you can wait until the E4300 is $113, which should be in a couple of months.
BTW, the 7300GT is better and cheaper than the 6600GT.
use it for is like internet, email and looking at pictures.
If true he will never even go into 3d mode, get the cheapest video card you can find.
Uh, i just realized that i dont think that mobo will work with that cpu. is that true? but idk because they have the same socket.
You could get a dell E521 from Dell Home for $350 no monitor.
AMD Athlon 64 3200+
NVIDIA GeForce 6150 w/ onboard Video/Audio/Lan
512MB DDR2-533
80GB 7200RPM SATA
16x DVD ROM SATA
Windows Vista Home Basic
If you go with building it, the only thing I'd suggest is a G965 Express chipset based board instead of the 945.
