Help! GA-H55N-USB3 - Power ON issues.
contrivance
Alright guys - I'd appreciate some help before I pull all of my hair out. I'm building a HTCP for my father and having a fairly big problem.
Here are the components that matter for this particular troubleshooting.
City Net ITP15080B PicoPSU-150-XT
GA-H55N-USB3
SAPPHIRE 100253HDMI Radeon HD 4650 512MB (low profile)
A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Intel Core i5-750 Lynnfield 2.66GHz 8MB
What happens is the computer will attempt to power on and then power itself off and then back on again - in a looping cycle. Although SOMETIMES I would see the splash screen before it would power off. One time it powered on and stayed on for about 5 minutes before I turned it off but I was never able to replicate it again. It also seems like the monitor recognizes some sort of signal (light turns from amber to blue) before the computer shuts itself off.
I tried a few of things:
-Unhooked everything except for the video card and RAM.
-Tried the RAM in different slots as well as trying each stick individually in different slots.
-I've also tried powering it on without the video card to same result.
I thought maybe the PSU is not powerful enough to push the i5 95w and the video card together but from the sites I researched the i5 draws about 88w at idle and the video card 30w at peak. Maybe I was reading the wrong information. Either way, could someone give me a few ideas on what it could be, or what other troubleshooting steps I could try?
Thanks!
Your power supply is no where near good enough to run what you are trying to run....
That PICO 150w PSU is pretty sick kit....it gave me so many ideas......he-he altho, it won't run an i5 proc. a discrete video card & that maiboard, even tho it's Mini-ITX...that PSU is designed for using a low power ATOM or similiar with on-board graphics....
Alright guys. I failed.
Can anyone suggest a mini-ITX psu that would fit the Antec ISK 300-65? I'm guessing I would need something around the 250-300w range.
None that I know of. SInce your motherboard supports it, why not get a Clarcksdale i3/i5? They have an onboard GPU that is comparible to an 8400gs, last I checked. They support HD bitstreaming of audio - the only complaint is a vertical refresh bug that affects Intel IGP.
I think you have way too high of a power requirment for anything less than a good quality (seasonic) 350 watt. 400 would be better.
Contrivance,
I've built quite a few systems around this motherboard(and the DFI counterpart). The i5-750, with a video card/monitor connected usually idles around 50w. Sometimes lower, sometimes a little higher. The i3-530 builds usually idle around 35w or less. Depending on the card.
The 4650 should pull about 12-13 watts in idle, but depending on the card, it can pull anywhere from 35-60w at the top end. I've played with quite a few of these...
So, it might be the initial surge the Pico is having a problem with. In 3d, you'd definitely be over the limits...or at least past the safe range(I consider this 150w x .80 = 120w) and if the PSU did boot up, once you ran the video card in BluRay or did some mild gaming, you'd be in trouble.
That psu you're pointing too isn't a bad one, but I'd recommend switching to an HD 5450(mine maxes in 3d at 16w).
for what it's worth, I'm running this set up with a Pico. i3-530, GS-H55N-USB3, G. Skill ECO DDR3 1333mhz, and an HD 5450. Idles at 31w. It hasn't given me any trouble.
If it was me, I'd reset the CMOS, take the video card out again and give it at least 5 tries to get it to fire up. If it does, it would confirm the PSU isn't handling the initial surge of the components. At least that would be my conclusion.
Whatever you do good luck with it.
Liquid Cool
P.S. I'll add, I took a look at the case. Why not just go to a Lian Li PCQ 07/8/11, and pick up a relatively efficient 400w PSU and be done with it. If you went with the PCQ-08, you could always upgrade to a large video card later(ie: expandability.) or perhaps even one of the Sugo cases from Silverstone if you're looking for something tiny...
Not to hijack this thread, but I am having a very similar issue as Contrivance.
I got home today to my lovely package from Newegg, and I've only had headaches the rest of the night.
Specs:
GIGABYTE GA-H55N-USB3 LGA 1156
Intel Core i3-540 Clarkdale 3.06GHz
Patriot G Series ‘Sector 5’ Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
SILVERSTONE Sugo SG05-B Mini-ITX Case with built in SFX 300W 80Plus Power Supply
Problem:
I keep having a similar issue that the system will turn on for about 1 sec then power off, then wait 2 sec and try again, then repeat.
What I've tried:
I initially connected the entire setup and then have gradually removed items to see if it would boot with the bare essentials. With just the motherboard, a HD, and the memory I still cannot get it to boot properly.
I thought it might be the power supply issue, so I hooked up a 500 watt supply and the same thing happened.
My brother bought the same motherboard, case, and power supply a few months ago. He has not had any issues. The differences between systems is that I got the i3 3 ghz and he got the 2.? chip, and we bought different brands of RAM.
Question:
So, I was really just looking for some suggestions of things I could try. I am getting together with my brother later, but other than swap around our components I'm not really sure what to try next. Would bad RAM or a chip act like this?
Thanks for any all help!
You might want to check the AC/DC Adapter you're using. I have a 150W PicoPSU matched with a proper 150W AC/DC adapter. Sometimes kits will bundle a 100W AC adapter, which is completely lame since it won't let you drive the 150W PicoPSU. For example, I have a 150W PicoPSU running a i3 540, H55N-USB3, and a GT240 video card. Everything is stable, idles around 60w, 130w while playing games, and 140w under furmark.
I am actually experiencing the same issue with my new config:
- h55n-usb3
- core i5 760
- OCZ ECO DDR3 2x2 GB 1333 Mhz
- Asus ENGT430
- Sugo Silverstone SG06 with 300W power supply
Did anybody found a solution to the "no boot possible" issue? Or is the motherboard simply defective?
Thanks!
Ru roh.
Just got back from vacation and I couldnt stand staring at my pretty Lian Li Q11 build any longer. I have been waiting on my PICO PSU for like 2 weeks now (im praying that itll be here tomorrow), so I had the bright idea to pull the PSU out of a shitty computer in my house so I could install windows/dick around with it.
It is a crappy "350w" psu that claims to have 16A on the 12v line. Anyway, plugged everything in and hit the power switch and it started to boot.
I saw the Gigabyte BIOS splash screen, but after about 2 secs I got some crazy black bars accross the screen and it started to go into a boot loop (powered off, and on again), each time I would see the screen but it would artifact and boot loop again.
I nearly shit my pants so i killed the power as fast as I could. Did I kill my new build?? The PSU works perfectly in the rig it was in (AMD Sempron single core clocked to 3.2ghz, 3hdds, and an old ATI 9800 GPU), so I do think the PSU had enough power.
Plugged it back into the old machine and it works perfectly. Ran furmark + p95 and it is working fine.
I am scared though, i hope I didnt kill my new gear :(
I guess ill have to wait until I get the PICO to really know :(
Could it just have been that the PSU was designed for an old system and wasnt feeding proper voltage to the MOBO or something? Every connector lined up (ATX 20 + 4 pin, 4 pin by the CPU, and Molex to SATA adapter for the Intel 120gb SSD). It did NOT have any SATA connectors though.
I am an impatient dumbass I think :(
System Specs:
Gigabyte H55N, I3 550, Intel 120GB SSD, 8GB Mushkin 1600 (@1.6v).
No optical drive and using the onboard VGA port on the mobo, I didnt try another graphics port and I refuse to try again with this PSU, I also didnt try to pull a stick of RAM out either. :(
Nope, it is 1000% the board. That PSU is absolutely fine (the 350w), and I just bought a 520w Corsair HX and it did not change anything.
It is still boot looping, HAS ANYONE FOUND A SOLUTION FOR THIS PROBLEM???????
Update the BIOS is what comes to mind for me. Also only put one stick of ram in and make try the different slots.
