Help!!! Front Panel Headers
delerium
I have a Antec Super Lan Boy, and a Biostar TForce 550 am2 mobo.
Ive got one led wire left to connect to the mobo....but wheres it go? i cant seem to find any headers that are apropriate for it.
the hdd led is plugged in, power led is in, but wheres this led go?
Does the case manual say anything about any wires (or connectors) at all?
its a yellow/white 2 pin LED
case instructions says plug it into the led headers on the mobo, but there isnt any that say led that i can tell.
Your board only has 2 LED headers, one for Power and one for HDD activity. Since the Super Lanboy comes with 3 LEDs, the 3rd one will be unused in your system.
This is correct. However you might have another device in your system that can take advantage of the LED. Sometimes a secondary HDD controller or something like that might have a header for LED activity.
Does this match your user's manual for tha case?
Connecting the Power Switch and LEDs
4. The Power LED, Hard disk activity LED, and SPEAKER connectors all share a single ribbon cable. Attach the POWER LED, HDD LED connector and SPEAKER connectors to the appropriate headers on your motherboard.
Doesn't sound like it. Did you hook up a speaker that is IN the case/front panel?
Tony
