Some gaming (SC2 on mid/high settings), Image processing DNA sequence processing.
Around 800-900 with tax and shipping, ideally. I could be convinced to go higher if it's worth it.
3) Where do you live?
Bay Area, CA
CPU, MOBO, PSU, HD, smallish SSD, GPU, RAM, case, optical drive, WiFi card
nope
6) Will you be overclocking?
Not likely
23"
ASAP, no big rush
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Nothing in particular, so far as i know. I guess something good for SSD.
64bit win7
Hi all,
Hoping you fine folks can give me a little hand with my first build. I'm looking to make something that's pretty good for gaming, but something under a grand. I was thinking i5-2500K and a ~60GB SSD as a starting place. The SSD is kind of important because I do a lot of microscopy and processing of images, so I'd like to be able to process on the SSD, then move the finished product to HDD. Room for another HDD in the future would be nice, so a case that can fit that would be ideal. I have OS.
So far I'm using this as a starting point.
This is what I have right now. The anandtech page mentioned something about a power cable adapter, so if you could tell me whether i need it, and what that might be, that would be great.
Input, comments, suggestions all welcome. If you feel like this is good so far, is this everything I need? Thanks so much you guys!
Bay Area, CA
nope
Not likely
23"
ASAP, no big rush
64bit win7
Hi all,
