Whoa there, ghostrider, gotta gimme time to write up the problems.Yeah can't you give any more information? I don't understand the point of your thread if you're not even going to say anything except "E6 cards are buggy". Means nothing.
Previous setup was a pair of the Sapphire 5870 1GB Vapor-X's with CrossFireX disabled for the most part because CFX didn't increase frame rates at all.Any more info? What do you mean by buggy - artifacts? What was your previous setup - a standard 5870?
base on several reviews, it looks fine to me..
maybe you got a bad card![]()
That's the problem with reviews, doesn't always tell the whole story.
With the new E6 card, I've experienced the DP flickering where it gets stuck in a loop of going into power save mode, then flashing the Windows desktop fine, then going back into power save mode, and so on. Workaround for this is to unplug one of the dongles and replug it. I've ordered some dongleless MiniDP-to-DP cables to see if it's a dongle issue, perhaps.
