Help... Error CPU is unworkable or has been changed.
TommyT
Hey everyone,
I decided to dust out my desktop with canned air today, something that I have done many times before without a problem. The only difference was that this time it had been more then a year as opposed to only a few months and this time I removed the cpu heat sync and cpu to clean or blow off the area under the heat sync and replaced the arctic silver. I cleaned off the arctic silver off of the cpu and heat sync with a little alcohol on a paper towel and replaced it with fresh. I then replaced the cpu and locked it into place installed the heat sync, all the cables and rebooted.
I get one beep and after the memory check a message that says:
CPU is unworkable or has been changed. Please recheck CPU soft menu.
I have reseated and locked the CPU several times now and I still get the same message. I also can't get into the BIOS. What gives???
TommyT
Possibilities: EDIT: check #3 first before panic.
1. Zzzzzzzzzzaaap. Electrostatic discharge.
Why is it that everyone feels the need to remove the heatsink/fan and proc from the motherboard when cleaning? I always leave the CPU in the socket, you can still clean it effectively, put on new AS5 and the cleaned HSF without risking ESD to the same degree as removing the CPU.
2. The other possiblity, and one you should check is if any pins where bent during the removal/replacement operation. If so, and you can straighten them without breaking them off, you may be up and running again.
3. One last possibility is that you'll need to press the DEL key as soon as you power the system on and press it over and over again until you get into BIOS. Maybe the CPu's fine and the jumper-free BIOS has lost it's settings and isn't autodetecting correctly.
Good luck.
When I've had that problem, I go into the bios and check the CPU settings (changing them accordingly) and then the error goes away.
QFT, you have an Abit MB and your BIOS was reset. No big deal, and nothing is broken.
Just go into the BIOS and set your CPU settings to the correct ones and save them.
==>Lazn
Ya, just reset the BIOS its not a hardware issue, mine says that when I reset the CMOS
