Make sure that the BIOS shows SATA/IDE on the Gigabyte controller as IDE mode. The Intel SATA controller can be anything you like, but the GSATA must be IDE if you have an IDE device on there. Don't use RAID/IDE or AHCI.
If you have SATA drives, put them in the Intel SATA controller and you can use RAID or AHCI.
On the Ds3 when using on board sound make sure in the bios that the "Azalia Codec" is set to "Enabled"ok now i have a sound problem. yes its been enabled in bios and driver has been installed but no matter if i enable or disable it , the audio doesnt show in bios at all. nothing device manager but codecs from windows.
Vista or XP?
I had a problem like that and I had to install drivers for the HD audio sound bus before it let me install sound drivers.
