Help creating my own power switch/jumper
I want to setup my old rig but I don't have a case right now and I need to turn the power on so I can install an OS onto it. Are there power pins on the mobo that I can jumper so that when I turn power on via the psu it automatically turns the mobo on?
if it's ATX spec board, then there will be a PW_SW (or something similar) pin header. That's what the power button connects to. If you don't have a power button, then you can (carefully) short the power switch pins with a screwdriver for just a second.
I figured it out like 5 minutes after I made this post :p I had a bunch of jumpers from one of my other motherboards and I'm using that right now as my switch. Initially I just shoved it on there and it would turn on but then turn off after like 3 seconds. Eventually I figured out that I did need to short it and then take it off. Thanks.
If you get an old case, you can take the power switch out and then have your own test switch.
Yeah, the power and reset switches are 'momentary' spring switches. So when you press them they only close the circuit for as long as you press.
One of the features of an ATX power supply and an ATX board is the ability to force the power off by holding down the power button for 5 seconds. So if you placed a jumper on the power switch header it would be normal for you to get exactly the behavior you described. :)
I usually keep a screwdriver handy on the test bench for these occasions, using it to make momentary contact between the two pins on the motherboard for the power switch. It's too much of a pain in the butt for my fat fingers to fumble around with jumpers all the time. :p
